Stock Intrusion bar shift???
HeavyDuty
Kevin
East of Nashville
2021 Lariat, FOX 2.0 (set at 2"), 275 65 R18
Builder, Restorer
I'm thinking about just shifting the stock intrusion bars.
Can you actually gain some more clearance just loosening and shifting the stock ones?
HeavyDuty
HeavyDuty
Kevin
East of Nashville
Builder, Restorer
Just went for it with a 15MM socket wrench and 15MM box wrench.
Took like 20 minutes.
Front left shifted 3/8" toward bumper Front Right shifted 5/16" toward bumper
Back Left shifted 7/16" toward cab Back right shifted 3/8" towards cab
Now granted the center of the bars didn't move that much respectively
but clearance is clearance.
That was easy - NEXT
I will agree that it's not a whole lot, but every little bit will make a difference. Also I recommend keeping those bars there as they are meant to help protect you as an individual in the event of a frontend collision.
HeavyDuty
HeavyDuty
Kevin
East of Nashville
Builder, Restorer
I think I'll be fine.
I'm about ready to install 265 70 18s on stock rims. I have a full 2" BDS front leveling lift.
Bob902
St. Louis
RETIRED!!!!
I have the Eibach front suspension set at about 1 1/4" of lift with 255/70/18 tires on factory rims. I have plenty of room so you should be good. We like pics, too?
You’ll be fine with that - your OEM wheel offset and the 2” level are doing you some favours but if you ever go to aftermarket wheels, keep your offset at +25mm or higher or be prepared to remove or replace those crash bars.
