Start Stop Feature on the 2.3L Ecoboost
joeb427
I hate the feature and have to deal with it on both my vehicles. I shut it off after start up.
Desert_5G
Desert_5G
Eric
Arizona
Tacoma
my auto stop eliminator has shipped :D Anyone else order one?
Krzydmnd
Pennsylvania
2019 ranger Xlt
I installed and tested it for Travis this past weekend. Cinch to install and works great . One thing when you go to install, you don't need to pull the center cover off completely, just enough to reach the clips and pop the button through from the bottom to unclip the cable. Srsly a 5 minute job.. You do need to use some muscle to pull the required trim pcs off so don't be afraid to yank on them
rangerdanger
SF Bay Area
Did you happen to take any photos during the process? It would make a good DIY post.
Oregon Comrade
Portland, OR
2019 Ranger FX4
Just saw this post, I did the same thing. Took me 5 min, I could do it again in half the time.
Pop the shifter cover off, slowly working around it with a couple flat head screw drivers. I didn't use painters tape, but may be a good idea. Any tape would work, duct or masking.
Getting the button out was easy once I figured it out. Not quite enough room for fingers. Use a long flat head screwdriver and push the clip on each side, once from the drivers side then from the passenger side, the button pops right out...install device, goes back together in 30 seconds.
Works great!
HighFivenWhiteGuy
Renton, WA
2019 Ranger Lariat FX4
I have been driving the truck for about a week now and the start/stop isn't perfect but it doesn't really bother me. I live in the Seattle area so traffic SUCKS. Freeways aren't an option so I end up on back roads a lot, and that means lots of stop lights. That also means a lot of idling, so having the engine shut off makes sense. After letting off the brake I give the truck an extra half second before going, that eliminates any awkward starts.
Krzydmnd
Pennsylvania
2019 ranger Xlt
Works great!
Did you pop just the shift cover, or did you take the cig lighter panel off too?
Josh_R
Josh
Akron, Ohio
2019 Ranger, 2004 Ranger, 2013 Edge
Turn on the defroster. I've yet to have the auto stop/start kick in with the defrost turned on. I always keep the defrost on at level 1, when the windows are up, anyway.
RCMUSTANG
Ray
Los Angeles
2017 Fusion 1995 Ranger
I test drove one after I made the deal for mine and the start/stop never engaged. Pretty much all the conditions listed above were met as far as I could tell.
Jason L
Mount Pleasant, SC
2019 Ranger XLT 302A
Compared to my last vehicle, the auto start stop is significantly less disruptive. I barely know its there, and haven't minded it as much.
