Squeaking when driving over bumps
Wytchdctr
Doug P.
Westside Htown, Texas
2021 XLT
Retired Military/HR Manager
Which brake cable? Does the noise on the front right side when you hit the brake?
Ebrake and somewhere from the rear.
After lubing the hell out of that brake line junction thing in the back.. so far so good but it has made a liar out of me before. I'll give it a week this time before claiming victory.
It being easy to reach makes it even better if that is the solution.
Wytchdctr
Doug P.
2021 XLT
Not a week but that actually stopped the noise.
Summary. The end of the flock of birds chasing me. (Sound wise.. I am not totally crazy)
One bolt was loose mounting the bed letting a bushing make noise anytime the road wasn't perfectly smooth, constantly. Fixed by the dealership after a week of searching.
The second sound was only during braking going forward at slower speeds. Far more intermittent. That was fixed by greasing the hell out of the ebrake junction thing just over where the axle meets the diff (the pic above).
Woohoo. Like the truck so much more now!.
BladeRanger
Bladimir
Escondido Ca
Ranger 2020 XLT FX4
Electronic Engineer
One bolt was loose mounting the bed letting a bushing make it make noise anytime the road wasn't perfectly smooth, constantly. Fixed by the dealership after a week of searching.
I'm using these to help the squeaking noise. Now they are gone. Thanks for the info.
Tremordan831
Dan
Monterey County, CA
2022 Ford Ranger Tremor
Govt
My noise was from the metal link where front and rear cables are spliced in the housing. Metal link rattled and squeaked. Shot lube over everything in the metal housing and noise hasn't returned
Porpoise Hork
Bret
Houston
IT
My truck now has a constant high pitched squeak up front right that goes away the moment I apply any brake pressure as well
Check to make sure the brake line mounts are secure where they bolt to the knuckle and inner fenders. Reach up in there and give everything a little wiggle to see if you can replicate the squeak. If not may also want to check the anti-rattle clips and caliper pins. You can apply some anti-seize compound where the pads contact them and on the pins. Also apply a coating of disk brake quiet to the backs of the pads.
Squatchranger
Orlando
19 ranger lariat
Its only when I am in motion the moment i apply any brake pressure it goes away doesn't change over bumps anything, just got my oil change and when they checked the pads a couple weeks ago they said they were good too which makes me think it isn't the brake wear clips
Squatchranger
Orlando
19 ranger lariat
So as I suspected I had some crap in between the pad and disk that was rubbing there was even a line in the disk where it was constantly hitting it so far cleaning it out has worked great
Ames
Iowa
2019 Crew Cab 4x4 Ranger Lariat
Civil Engineer
I am now dealing with this. I thought it was in the cab but it has something to do with the box. If I lift up on the box at the wheel well on the driver's side and let it back down over and over, I get a sound like a glass bottle rubbing on a styrofoam cooler. It's really loud in the cab and I have only noticed it since the weather has been cold. It sounds like it's coming from the space between the bed and the cab.
BladeRanger
Bladimir
Escondido Ca
Ranger 2020 XLT FX4
Electronic Engineer
I have that squeaking sounds coming from Fox 2.0, it's resonating on my tubular UCA, I used a lubricant from Ford and it gets rid of the noise.
dokoroko
usa
ranger
If you get under the truck and look up at the gap between bed and cab you'll see where they contact. On the quiet side of your truck there will be a a tough black material between the metal of the bed and cab. The loud side won't have it, i believe that's where the noise is. When I rock the cab, there is no noise, when i rock the bed there is a noise. It's the movement between the 2 causing the problem.
Ames
Iowa
Civil Engineer
I'll check it out! This is the time of year when normally I start to hear it.
HeyRob
Full-Time Travel
2021 Ford Ranger FX4 Lariat
IT Consultant
Not sure if there’s a “don’t revive dead threads” policy here (and please forgive me if there is), but I have had the same issue. Very noticeable when going over speed bumps with the windows down.
After glancing around (and having wife jump up and down on rear bumper like a lunatic) and getting the laughing to quiet down, I discovered it was the spare tire mount mechanism. There is a short 1” or so spring that sits on the bottom side of the spare tire bracket that keeps constant spring pressure on the bracket that holds the tire against the pads on the top side. My guess is it was giving a little over the speed bumps. A little silicone spray cleared it right up!
Just thought I would share. Apologies again if I shouldn’t have responded here.
RangerBill
You might want to tighten up the spare tire a little with the crank.
