Spare Protector - Underbody Spare Shield Install, Photos and Remarks.
lazynorse
Washington State
Ford Ranger Crew Cab XLT FX4
Public Health
Seems there's exactly one company making an underbody spare tire shield, www.spareprotector.com. I bought off his ebay site, $135 (search underbody spare tire cover protector). The product is thick ABS plastic material that covers to the shoulder tread of a 32-33" tire. I wanted something that would protect against a possible puncture from a departure angle mishap, or a sharp branch flipping up as I drive over. Or, just road crap. There's holes at the lowest part of the cover/shield to drain water.
It feels more robust and stiff than the plastic fuel tank cover. I don't think the strongest among us could plunge a knife through it. I would think it could scrape along a nasty outcrop of volcanic rock and protect the spare sidewall.
I originally fitted it to mate against the lug hole side of the spare tire rim - mistake, this results in a 2" open gap between tire and outer rim of shield. You mount the shield on the 'empty' side, so the tire/rim's lug hole area is facing up. There's reinforced metal disc on the shield that supports the spare tire wing nut/hoist chain. The owner confirmed this by phone (more on that..).
Small problem #1, the diameter of the shield hole is a tad smaller than the spare tire rim hole, and the wingnut has a raised section that recesses into the spare for a level fit. Since that raised area doesn't go through the shield hole, the resultant wing nut fit is a little canted on the side. That said, it seems like an adequate amount of force, surface area and hold. Once hoisted up, I found no budging or play, flex or other concerning things.
Small problem #2, there's a piece of the hoist wing nut that is pointed 90 deg up, that goes through a spare tire lug hole. There's not a compatible hole on the shield. I grabbed the wing nut in one hand, and with pliers in another I bent that 90 degree piece of metal down flat with the rest of the wing nut.
Due to those fit issues, I called the company. Owner picked right up and asked for photos. Said these work for nearly all vehicles but there's a couple of exceptions (F250s and 350s have too big of a wing nut on their spare hoist). I get the sense this guy is pressing them out of his garage. At any rate, I was impressed he chatted with me for 10 minutes on what I thought and saw, my intended use. Said he'd get back to me after reviewing photos. Also said he's developing a spare tire topside hardcover, asked if I'd be interested. Maybe..... not sure that's needed.
I searched and searched, there's nothing else like this out there. If you're enterprising, you could compete. While not a shield, there's spare fuel tanks - fuel and water - that fit similarly in the recess of a spare tire. That is a huge pain to get to and I wouldn't do it, but thought I'd mention it.
Photo 1, the nice tight fit. Photo 2, close up of slightly canted wing nut fitment against shield. Photo 2, detail of that little metal tab I bent back down from 90 degrees.
Interesting product...
When you absolutely, positively, have to spend money.........
I would think that just moving the spare to the bed interior when off-roading would take care of both problems....keeping the spare undamaged, and increasing the departure angle.....
lazynorse
lazynorse
Washington State
Public Health
In the world of exterior mods, this one is cheaper than many or most, certainly cheaper than any skid plate (I have the full RCI aluminum set). Also cheaper by order of magnitude than a bumper swing out option. We don't just go off roading, we go offroad on 2 week camping road trips. The back of the bed is spoken for, so bed storage is not an option.
I've got a 3" suspension lift and 255/75/17s. Even on 'moderate' trails, where camping and exploring are the goals - not rock crawling - I've had a couple unanticipated departure hits, as evidenced by a little rash on my exhaust and hitch bottom. The spare sidewall is right along that plane. Removal of spare does not increase departure angle, at least not removal of a 255. It is theoretically vulnerable. My spare is a matching Firestone XT C Load, not inexpensive. I would absolutely rely on it in the event of an irreparable puncture of any other tire, 50+ miles away from any services, probably along the same stretch that punctured the other tire.
I also have a $50 sidewall repair kit (in addition to normal plug kit, which I've used once), which really made me wince but it is a proven product. We venture to remote deserts of SE Oregon, SW Idaho, Northern Nevada (that ones coming up in May), and Utah. My vehicle prep question is always about what is prudent to prevent an inability to return safely. Tires, suspension lift, skids, maxtrax/basic recovery kit, tire repair and satellite communicator round out that safety buffer. I considered it long and hard, ultimately deciding $135 is not too much for something that protects the spare.
If this were just a pavement truck, I would not buy it.
As one who also travels OffRoad frequently and has a spare tire under the bed(I have considered relocating, but have yet to justify at this time), I'm going to have to side with @Grumpaw on this one.
Don't get me wrong, I understand how much the Firestone Destination XT is. Technically I'm on my 4th set. That said it is a very durable tire and will take a hard hit without question. If you are traveling where you feel the spare tire is going to take a hit, then you need to find a way to relocate the spare tire. Simple as that. I know it may be expensive depending on how you do it, but it may be the better option for you.
lazynorse
lazynorse
Washington State
Public Health
Sure, but for $135 I have a lifetime of protection, don’t need to relocate. No branch will get through that ABS. Sidewall is safe.
At HWY pressure a stick can still puncture that tire. Look at how much is not protected....... Keep in mind that on my 2012 Frontier I have a matching spare that is also a Firestone Destination XT and I am not concerned. I decided to save that $135 for a different item that will be more useful.
lazynorse
lazynorse
Washington State
Public Health
All valid perspectives, I’ve wrung my hands over whether this area is vulnerable, and if this product is worthwhile. Can’t say for sure if i’m right or wrong. I’ve covered my transmission, why wouldn’t I cover this spare? It’s equally vulnerable, I think. This covers 95%. Might not be right for others. I’m just sharing the option.
Friday yet?
ā€˜23 Lariat Tremor, Focus ST
? drop
Friday yet?
Spot on OP. Beauty of truck ownership is we all have opinions. And they are influenced by, among other things, our individual needs. Lastly, you know this crew is NOT going to miss a chance to give someone a bit of ?!
dozxab
Prescott AZ
I replaced my my spare wheel with a matching one that goes into a 5 tire rotation. I got a cheap Jeep spare tire cover to put on top. When I took the spare down, I had an accumulation of gravel and golf ball size rocks up there and didn't want that on my shiny new wheel. I like the concept but the worst I do is old fire roads. There are actually as many miles of those in my county as paved roads.
Dereku
Chicagoland Area
Neat product. Never thought of protecting that.
