Show yours, if you have this issue
Muffin1
Muffin1
NJ
Just to change the subject a little, how did you reach in there to clean out between the cab and bed?
I used a grabber pickup tool it has claw type at one end and you squeeze the handle to open/ close the other, I would post a pic but misplaced the dam thing somewhere,lol.
Cabose-1
Eli
Student
I got a friday truck. My hood fender alignment is crooked, front bumper crooked, driver door crooked, i do not want to check the bed. And one of the tailgate cables is loose, just hanges while the other is tight. So if i keepnit covered in mud, and have the inside bed all scratched and dented, and never unhook the trailer,
the truck is perfect! ?
LostMy65
Robert
Ranger
What ever you do don't measure the lean to the left especially if you have a full tank of gas. You will never unsee it. ?
Lean to the driver's side or passenger's side?
LostMy65
Robert
Ranger
I forgot all about that Friday & Monday truck stuff. That was something I used to always check.
Scatch85
Dan
Charleston SC
2021 Ford Ranger
Analyst
Mine is probably off a bit. It came with a loose bed from the factory. The robots were sleepy that day.
Where I work granted we build large aircraft with tight tolerances, but the robots do jack things up from time to time that's why we have a person watching to make sure it's being done right. We also have inspections after the fact by people. Gaps and alignment issues definitely get shimmed as necessary to meet engineering expectations.
Granted a bed out of whack isn't going to do much but I can't see a cab being out of tolerance not causing a safety issue after a certain point.
Maybe I'm just looking at it filtered from my experience where when drilling by hand you are allowed +/-0.005" flushness and +/-0.02 deg angularity on holes/bolt installs.
I have an 1986 F-150 I'm restoring and half the rust was caused because the automotive spec was just screw everything through the floor without any water sealing.
