Is this HVAC issue normal???
orangegrower
AZ
2019 Aston Martin Vantage - 2019 Shelby GT350 - 2019 Ranger Lariat
I bought my 2019 Ranger Lariat new when I was living in the Phoenix valley. So I have used the heating mode maybe a few times in my 5 years of ownership. I recently moved to northern Arizona that gets some winter weather. This morning it was 35 degrees and after starting the truck with the AC in the "AUTO" mode the fan was at full tilt but no air coming from the dash vents or upper dash area. The only air flow I could feel was floor level. Switching to manual mode resulted in good hot air from all the vents. Is this normal or do I have a problem. Any help would be appreciated.
JohnnyLightning
Orlando
2020 Ranger
Pilot
If I understand you correctly, yes, that is normal. I think all cars blow full heat at your feet when it is trying to make a cold car warm. The ranger doesnt really blow wind to your feet I think the foot vents are up a little high and it blows some air under your front seats. As it approaches the selected temp in will make some air come from the dash board vents.
orangegrower
AZ
Thanks for the response. I guess I am happy the truck is not broken but also unhappy that it is designed that way.
Dgc333
21 Ranger Lariat
I have owned 5 Ford products with dual zone HVAC systems going back to 2011. They all work this way. After the first one I never use Auto mode. In the winter I manual set the vents to defrost and floor, in the summer I only use the dash vents. I manually set the fan speed as needed.
hughesjv
Aurora, CO
2019 Ford Ranger Lariat FX4
Our Honda does the same thing...it is to keep cold air from blowing in your face and it helps the system regulate the cabin temps including side to side.
