School me on tire size… pretend I’m 12
LukeB12
Denver
2022 Ranger Lariat 4x4
I just recently purchased a 2022 lariat and have begun the process of adding many of the deleted features and some of my own add ons as well (pictures to follow soon) I have the 17 inch rims and want to put “beefier” tires on. Both to survive the upcoming Colorado winter, and for the aesthetics. The only problem is I have no idea what “beefier means” I downsized from a ram with 265/65/20s and had bf Goodrich ko2s and loved the look. How do I replicate that look/ what tire size can I put on without needing modifications? (it will be leveled shortly). The stock ones are 265 65 17 and are just very little looking. Thanks in advance for any help and knowledge! I have greatly enjoyed learning so much more about my truck from you guys on this site, granted it’s a 2022 lariat so it’s been slightly disappointing when I got to the deleted list thread lol.
I just recently purchased a 2022 lariat and have begun the process of adding many of the deleted features and some of my own add ons as well (pictures to follow soon) I have the 17 inch rims and want to put “beefier” tires on. Both to survive the upcoming Colorado winter, and for the aesthetics. The only problem is I have no idea what “beefier means” I downsized from a ram with 265/65/20s and had bf Goodrich ko2s and loved the look. How do I replicate that look/ what tire size can I put on without needing modifications? (it will be leveled shortly). The stock ones are 265 65 17 and are just very little looking. I know nothing about tires and don’t know if 265/70/17 is a beefier or what other tire. Sizes would fit. Thanks in advance for any help and knowledge! I have greatly enjoyed learning so much more about my truck from you guys on this site, granted it’s a 2022 lariat so it’s been slightly disappointing when I got to the deleted list thread lol.
Age 12, Eh? Okay...put the damn phone down! Look at me...Take the ear buds out of your ears...
Sheesh... I give up....I am out of here....
Chris M
Surprise, AZ
2021 Ranger XLT Sport 4X4
Security Supervisor
Ah, the good old boomer humor.
Kind of a sad humor only because of the truth of it.
And they don't have to be 12 for us to need to say that to them.
CO2Ranger
Best thing to do is search the forum profiles/build threads and find someone's truck that you like. Then explore from there. Wheels/tires (much like oil choice) is a very deep and dark rabbit hole. ?️
Chris M
Surprise, AZ
Security Supervisor
Search through the Showcase thread for that.
Lots of exceedingly nice trucks with the stance you're looking for in there.
Progeny2021
Charlotte, NC
We’re happy you’re here. Let’s start with the basics, as you requested. You’re welcome.?
This all day.
You probably don't want to increase tire size until you lift/level the truck anyways.
Without a level you can only go up a little. And it would be a waste to buy 31"s today when you can fit 33"s in 2 weeks, or whatever.
Spend some time researching what YOU want. These aren't Toyotas, there aren't endless options. You're limited enough that by clicking around here you'll be able to figure it out.
If you, OP, "build" your truck by just asking for the mod "formula" and following that you're gonna end up with 275s on a spacer level with 0 offset wheels, fender flares, and a tailgate damper.
Not that there is anything wrong with that.
I said it more nicely this time. Hopefully nobody gets butthurt.
DonB
Don
Texan trapped in Communist Delaware
2022 HPR Ranger Super Cab FX4
Phil's one of the funniest yet most brutal people around here. I have a serious man crush on you
Sanctus Rimor
here not there
truck
Wait until you lift/level to change tires
The two tires you listed are the same width, and have the same treadwall height. The ram tire was taller because of the bigger rim. If you decide to upgrade wheels, stick with 17 or 18 inch.
Do you understand tire sizing?
265 is a measurement in mm, and that is the width of the tire. 65 is the aspect ratio and is a percentage of the width and determines the sidewall height. A 265/85 will be exactly as wide as a 265/45 but will be significantly taller and have much more sidewall.
Check this link to see how sizing works/looks
https://tiresize.com/comparison/
Danager
Dan
Alberta
2019 Edge
Manager
On the stock wheel and suspension height, 265/70/17 is about the biggest tire you can safely use without issues (Tremor runs this without issue). If you are looking for winter tires, consider function over form. Maybe go with the beef for summer (that’s what she said!).
Maybe the look you want has more to do with the tire design. You had a great off-road/all terrain tire on your last truck. That tire also had an aggressive sidewall. Questionable how much function that adds, but it looks nice. I attached a couple of the common tires that have a similar side profile and are available in the size you already have. The KO2 seem to have the most aggressive look, then the Toyo, and so on…. The more aggressive the look and the tread, the louder the tire tends to be - so prepare for that as well. You are also going to need to choose if you want white lettering (showing) or not. This depends on the tire and the vehicle, and YOUR preference. For me, I am split 50/50. Maintaining white lettering is more work, so I opt for the black side out look.
If you level the front, it seems as though you can go to a slightly bigger tire (wider and/or taller) with maybe only needing a spacer.
265 70 17 is a good bit more beef and fits the rangers bone stock. the kos bf goodrich is a great tire. look for a tire that is winter rated with this symbol. looks like a mtn with snow flake.
Living The Dream
Here is 265/70/17 on 17x9 tires. Raining today so you'll have to look through the raindrops to see it.
Mine is slightly lifted (Bilsteins in front at 1.8", Tremor leafs in the rear) but a lift is not necessary to run this size.
IMO, the 265/70 looks "Just Right" on a stock or mild truck.
With that said, when these wear out I'll likely install the modified intrusion beams and go with 285/70.
JohnnyO
Jon
Pittsburgh, PA
2020 Ranger STX 4x4
265/70-17 is about as big as you can go without rubbing or adding a level kit. Same width as your stock tires but a little taller. That's what I have.
Bocephus
Las Cruces,NM
2020 for ranger XLT 4X4
Jack of all trades
This is good info for everyone, I ended up with some Gladiator X-Comp M/T 265/70r17 on my stock rims with fox leveling kit. Last long too.
https://www.discounttire.com/buy-tires/gladiator-x-comp-m-t
Have you reinstalled the deleted tailgate damper?
