Report your MPG
Jeffsmith13
Clever, Mo
2020 Ranger xlt supercrew 4x4 iconic silver
Railroad engineer
1900 miles 4 door 4x4 87 octane, 25.2 mpg and getting better. Drove over 100 miles round trip half rural highway half off road in the Mark Twain National Forest. The more I drive it the more I like it. Factory rubber sucks though.
TylerV76
Tyler
Oxford, Michigan
2019 Ranger FX4
Emissions testing supplier
I did a bit of experimenting over the past 8 weeks and found that the only advantage premium fuel (93 octane) gave me was a more responsive engine. As far as MPG went, it made no difference at all.
4 weeks of 93 Octane:
Week 1 (lots of highway)
Week 2: Lots of highway
Week 3: Mix
Week 4: Mix
4 weeks of 87 Octane
Week 1: Mix
Week 2: Mix
Week 3: Mix
Week 4: Mix
Phoenix, AZ
2020 Ford Ranger Lariat FX4
Environmental Engineer
Over the first 2000 miles with 6 refuels, the last 4 being 91 octane, first 2 being 87, I averaged 22.6 mpg, all on-board computer. Level kit on for two plus weeks, original tires. No appreciable difference in mpg. Replaced Hankook 265/65-17's with BFG KO2's 265/70-17's several days ago. Only 90+ miles on it since but running at 20.3 since new shoes. Tracking manually now since with new tires and having not reprogrammed, may not be showing accurate
Gizmokid2005
GA
gizmokid2005.com
SQL Developer
Just remember, if you didn't change anything, tracking manually isn't going to do anything for you either unless you're tracking actual miles traveled outside of the truck. An uncalibrated tire size affects odometer/trip and speedo.
Phoenix, AZ
I guess I hadn't thought that through entirely. That makes sense. Oh well, guess it might be a bit longer before I know for sure. Thanks Gizmo.
jsphlynch
2019 Ford Ranger XL
Stock XL 4x4 crew cab here, running exclusively 87 octane.
After about 6500 miles (most of it around town because...well...covid), most tanks are now coming in around 22-23 mpg, after my first couple tanks being ~19 mpg (hand-calc, though I've done the AFE adjustment and computer averages pretty close to hand calcs). I think it's starting to drop a little as the weather has cooled.
This past weekend I finally had my first trip in the pickup that was long enough to have tanks of almost exclusively highway driving, and I also had a tonneau cover on. Computer said I averaged 26.1 and 26.4 on those tanks (hand calcs said 25.4 and 27.0). On my old Ranger (2003 Reg Cab, 2.3L, RWD), those conditions would have gotten me around 29 mpg. I am thrilled that I can get so close to the same mileage with the dramatic improvement in capabilities.
Gizmokid2005
GA
gizmokid2005.com
SQL Developer
Yup! That was one of the primary reasons I finally got a USB OBDII scanner and FORscan, since dealers are apparently unable to alter that config.
Phoenix, AZ
I have the ProCal 4 calibration tool coming in early next week. It supposedly has the capability for "speedometer correction for gear/tire change (within factory parameters). We shall see.
Gizmokid2005
GA
gizmokid2005.com
SQL Developer
Yeah, any of the tuners should be able to handle it as well.
HenryMac
Mech. Engineer - Retired
Still averaging better than 26 mpg in our FX4 Coupe here in the mountains of Central Colorado....
Filled up earlier this week and ran the numbers: 26.34 mpg
Chattownranger
Chattanooga
2020 Ranger
Mechanic
I didn’t read through this whole 34 page thread but just wanted to share an app I’ve used on my phone for years called Fuelly. You can track all sorts of maintenance related services and the like and obviously fuel mileage. Here is a screenshot of my rangers info. It’s a fantastic app I picked up years ago in my VW tdi days.
Rocinante
Matt
Memphis, TN
2020 XLT FX4 302A, '99 BMW K1200RS
FX4 Supercrew here. Only ~1500 miles and have been running 91-93 octane since the second tank. All stock except for a soft tonneau cover and my driving consists of probably 70/30 hwy/city driving with hwy speeds averaging 65-70 mph. I mostly drive like a granny around town and only open her up on hwy on ramps.
I use Trip 1 for each tank mileage and Trip 2 for historical mileage. So far, my individual tank milage has slowly been increasing with my current mileage around 24.5 mpg. Historical mileage has been increasing too (because individual tank mileage is increasing) and currently sits at 23 mpg.
Frog9z
Brad
Blue Grass, Iowa
2020 Ford Ranger
First tank thru mine, Supercab 4X4 with the black appearance 18" wheels/tires. I calculated 23.3 MPG with mixed erratic driving. 50% on gravel/ city and county roads/highway. It is only going to get better!
Much better than THE EC 4X4 Colorado I had.
On a side note the mileage remaining is pretty accurate like our Escape. I will not forget that.
My Colorado had a bigger tank and the miles remaining were conservative. We have a Chevy HD and it is the same.
