No issues with my Ranger, but my Fusion seems to go non-responsive if it sits for more than three days without use. I’m thinking it could be the car battery getting low since it is just about three years old. I will be taking it in for a battery check.Anyone having issues with the Ford Pass App not working? Will not update or start vehicle on most occasions.
Just once in the last 2 months, I believe I read somewhere if you use the key to start 3 times in a row without using FordPass it has to relearnAnyone having issues with the Ford Pass App not working? Will not update or start vehicle on most occasions.
Found this out over time. If you use FordPass remote start and once used delete the user entered data. If you try to reuse a previous entry app will sometimes catch it or just not work at all.Anyone having issues with the Ford Pass App not working? Will not update or start vehicle on most occasions.
Google play store says mine is up to date. I'm still wagering clouds were what my issue was. It just seemed really convenient that the one day I had issues someone else on the forums started complaining too.I’m on an IPhone. The app updated 3 days ago. Sure y’all aren’t on the current version and your trucks sync is up to date? I’m having zero issues with mine.
Mine is doing the same thing on location. Shows the Ford plant in Michigan. Crazy. When I search for my current location it shows the right thing.I was having a helluva time getting it to work this morning, it just refused to turn the truck on all morning, I assumed it was cloud coverage since it's satellite based, right?
Worked fine in the afternoon.
It also refuses to believe my truck is sitting in my driveway. The app still shows it sitting at the plant in Michigan.
For those that have trucks showing the vehicle is in Michigan, check the Fordpass setup in the Sync settings and make sure that the location reporting is turned on.Mine is doing the same thing on location. Shows the Ford plant in Michigan. Crazy. When I search for my current location it shows the right thing.
glad it’s showing Michigan instead of Mexico. We do have the highest percent of USA parts and pieces. Wondering if the site is an assembly plant?
I literally just realized this and was about to report back. I finally turned my truck on and just sat in the driveway to play with the settings and noticed that location is defaulted to off in the sync menu. ?For those that have trucks showing the vehicle is in Michigan, check the Fordpass setup in the Sync settings and make sure that the location reporting is turned on.
I'm always complain to CS and ask if theres a recall for this issue or something else like SAGGY LEATHER SEATS, I get same BS and I get the same BS at the dealer.Has anyone reached out to Ford or directly to the Ford App customer service? I have reached out to both 3-4 times and neither will take responsibility for the problem. They won’t even admit there is a problem with so many customers! ??
