Redarc Tow Pro Elite Install
Edsel
North Carolina (Wilmington)
2024 Jeep Wrangler Willys 4Xe
Engineering Professor
Reading the other thread about the new version 3 model that Ford is selling now (that has the extra Lumen module for the AEB), would anyone agree this new version is the way to go OR is the "older" Redarc version good enough when you can just turn off the emergency braking feature?
Think about resale. Go with the OEM (VKB3Z-2C006-A) and mount the control switch in the shift console. If you do this yourself, be prepared for a wild ride. My wife went ballistic--"You are tearing apart your brand new truck! Are you insane?".
MINI Ranger
Gene
2019 Ranger Lariat FX4, 2014 MINI Cooper S Clubman
ASE Master Technician, MINI Technician, Retired
You have to pull the kick panel to the left of the fuse box. They are not easy to find and, IMNSHO, cut too short. IIRC, they are bunched together with some blue tape. All that are used are the blue and yellow and getting the heat shrink off the end of them is a PITA. Of course, you can follow the instructions and just cut it off completely, but later you will be wishing for that extra 1/2" or so.
I had the same issues with wire length and shrink fit removal.
I also noticed that wire size was not the same diameter on yellow and blue wires.
Douglrowl
Keystone, SD
2019 Ford Ranger LARIAT SuperCrew®, 5' Box, 4x4, 2.3L EcoBoost Engine
I got here just an hour AFTER I ordered the fascia panel. The install in the hole for the second 12v plugin is genius. The Facia panel is in the mail and the install shop is not charging me any extra, so I'll continue with that more expensive option. It will look nice. For those with 4x4 knob on the center console, the control head (allegedly) won't fit. The installer "looked under there" and told me there was not enough toom. I'll attach a photo of where I'd hoped te control head to go.
Douglrowl
Keystone, SD
Well, now I see the photo that it DID fit. Sorry for the confusion.
Jerry Caldwell
Jerry
Granbury, TX
Ranger Lariat
Retired Architect
They are telling you a story because they don’t want to fool with all the interior panels. Position A is the best.
Snorebaby
Augusta, GA
Position A is where I am putting mine.
Travis11
2019Tacoma
Im 100% sure it will fit, the under side just has to be smoothed out.
Hambone437
‘19 Ranger Lariat 4x4 Magnetic Gray / 2020 Explorer Limited RWD Magnetic Gray
Option B and C are not an option because there is a cross member piece of plastic. A is going to be your only option.
Lukaranger
Ontario, Canada
Ranger XLT Sport
Here are a few pics of my Tow Pro Elite installation from two weekends ago. I used a Redarc round mounting panel (part# 331-TPSI-003) which is made for of all things...a Chevy Colorado. It actually looks pretty clean in place of one of the 12V outlets. I had to slightly modify the mounting panel to fit in the hole where the 12V outlet used to be, but otherwise the installation went smoothly. Wires were exactly where they were supposed to be, however the violet wire was partially hidden by electrical tape. The control box is mounted under the steering column with a couple nuts and bolts through the metal cross support. There was plenty of clearance behind the outlet for the control knob body and cat5 cable. To ensure everything works: I towed my travel trailer over 200 miles this past weekend and the brake controller worked perfectly. If anyone has questions, let me know. The total project took about 1.5 hours.
Did the round mounting piece fit snug into the original hole? I`m just finishing the same way you did but its loose.
AND can anyone confirm that the battery does need to be disconnected when splicing the 4 wires together?
Rick - Saber
NC
Sport Ranger 4x4
Installed the Ford approved Redarc / Lumen TBC in my truck the other day. Some of the clips were a royal pain in the butt. The kit itself is very nice. The instructions could have provided a little more explanations in my opinion. Ford, I might have paid extra for a little longer wiring to connect to.
As an old school electrical tape kinda guy my question is about the shrink wrap butt connections with the metal collar in the center. For those of you who used them is the metal ring supposed to melt completely like solder to a soldering iron? The instructions say not to crimp, which I did not. My heat gun is about 1500 watts and it shrunk the tubing easily but did not seem like it melted the collar much, shrunk it a little it seems.
I even went to youtube to look up that style of connection and in those videos it seems like they melted up alright after only a few seconds of heat. Mine do not want to even after a second round of many seconds. Long enough to be concerned about burning off the shrink tube or damaging stuff in the surrounding footwell. The connection seems solid enough, how was your experience with these things?
aeroshots
2020 Ranger
I don't have a direct answer for you. But since you posted Friday I'll share my experiences. I've used those type of connections many times. Like them a lot. Have the same concerns. Some have melted like solder while others simply shrink. So.. don't know ?
mrgary321
Gary
2020 Ranger Lariat 4x4
retired engineer
I'm coming up on about a month of ownership with my Ranger and I love it. 7,500lb towing capacity is great but in most states you won't be able to tow anything past 1,500lbs (legally). A big mis-step by Ford is not offering or including a trailer brake controller at launch, and at the very least the uncertainty and/or mis-information by salesman, parts and service staff, vendors, etc. The install was in my opinion very easy and straight forward and could be installed by someone with basic electrical skills. Took me a little over an hour from start to finish, including replacing the fascia below the radio. I'm hoping that this post might help anyone that might be considering going after market or may be a little hesitant in installing a brake controller themselves.
I decided to go with the Redarc Tow Pro Elite https://www.etrailer.com/Brake-Controller/Redarc/331-EBRH-ACCV2.html ($202.10) because of it's small foot print and ease of install. I'm a pretty stocky guy and downgrading to a mid-size truck, I was concerned with constantly banging my knees on a brake controller module or having it rattle around over time on off-road trails. The Redarc module can be tucked away and mounted in any position and the remote module is very small and can be easily mounted anywhere with a few inches of clearance. While I thought that I would miss a screen readout of the braking status, the times I've been in vehicles with the Tow Pro Elite, the feedback from the color changing LED from the remote gives just the same amount of information as my old controller but in a much simpler way. We also regularly tow an off-road tear drop trailer so having that second user control mode where the trailer does not brake proportionally when the truck brakes that I can control manually and independently on the trailer is handy off-road, especially during steeper descents or climbs when I'm trying to maintain inertia of my truck but need to brake the trailer.
I originally intended to mount the remote controller in the center console right below the Trail Control knob. This is also where Ford installed their Redac brake controllers on their Ranger tow vehicles at pre-release media and sneak-peak events. I would have preferred some place higher on the dash within eye level but I didn't think there that had enough rear clearance for it. I didn't really like the idea of having to look that far down while towing to get visual feedback, so I ended up ordering a Lightforce fascia kit from Australia for their Rangers hoping that it would fit, prepared to mount it in the center console if it didn't. Luckily it fit like a glove and the details to it were posted here:
https://www.ranger5g.com/forum/threads/lightforce-switch-faschia.1908/
Here's a link for the Redarc Pro Elite's instruction manual:
https://www.redarc.com.au/Content/Images/uploaded/Manuals/EBRH-ACCV2 Instruction Manual.pdf
Ford Service Manual Towing Wiring Diagrams thanks to @FLEngineer :
https://www.ranger5g.com/forum/attachments/wiring-diagram-towing-7pin-pg4-pdf.3922/
https://www.ranger5g.com/forum/attachments/wiring-diagram-towing-7pin-pg2-pdf.3923/
https://www.ranger5g.com/forum/attachments/wiring-diagram-towing-4pin-pg1-pdf.3924/
https://www.ranger5g.com/forum/attachments/wiring-diagram-towing-7pin-pg3-pdf.3925/
On to the install:
1. Disconnect the negative terminal of the battery. Make sure you have something preventing it from arcing back over to the terminal.
2. Locate the four trailer wires on the driver's side kick panel on the left side. Yellow/Orange(Red), Green/Black, and White were taped together, coming out of the firewall. The first time I looked for the wires, I missed the Violet/White because it's actually taped to a different harness to the left of the three other wires. On my Ranger, the whole butt connector end was taped over so it looked like one continuous normal wire.
The four wires are:
  1. White - Ground
  2. Yellow/Orange(Red) - 12V Power
  3. Green/Black (Solid Blue according to Ford Service Wiring Diagrams) - Trailer Brake Controller Out
  4. Violet/White - Brake Light Trigger (Brake On/Off)
Note: On my truck (Purchased 01/2019), Trailer Brake Controller Out Wire is Green/Black. According to Ford Service wiring diagrams, the wire is supposed to be blue. On newer NA Rangers, it has been reported that the TBCO Wire is Blue.
The Tow Pro Elite comes with a wiring harness that plugs in to the main unit and the other end has 4 wires that you will be splicing to the Ranger's tow wires. The wires on the harness are:
  1. White - Ground
  2. Black - 12V Power
  3. Blue - Trailer Brake Controller Out
  4. Red - Brake Light Trigger (Brake On/Off)
3. Butt splice the wires from the included wiring harness of the Tow Pro Elite to the corresponding four wires in the kick panel. BE SURE THERE IS NO POWER RUNNING IN TO YOUR WIRES BY MAKING SURE THE BATTERY IS DISCONNECTED. Cut off the black ends of the four wires of your Ranger. I used Crimp & Heat Shrink Waterproof Butt Splice Connectors because I was originally planning on routing the wires under the carpet in the footwell and because of snow and post-surf days when it's too cold too properly towel off and I just jump in to my truck wet. Although regular butt splice connectors are probably fine.
If you've never butt-spliced wires before it's pretty straightforward. You strip off about .3" of the wire sheath exposing the copper wire. Insert the exposed wire in to the barrel. Do the same with the wire that you will be splicing together into the other end of the connector. Then crimp down on the barrel. Slight tug to mke sure that you crimped down hard enough and that the wires aren't loose. If using heat shrink tubing, heat shrink the tubing with a heat gun, making sure to evenly heat all sides of the connector. Careful if using an open flame. If you mess up, you can always cut the wire and re-strip. Be mindful of where you cut and splice the wires, the more wire length you keep, the easier it'll be when routing it towards the main unit wherever you decide to place it.
4. Find a suitable place to mount the Remote Control Assembly. You'll need a minimum for 46.5mm plus a recommended distance of 43.5 for the RG45 cable that connects the main unit to the remote head assembly.
5. Once you've chosen a spot for the remote assembly, you'll need to drill 2 holes in to the console panel/dash panel/knockout switch. One 10mm in diameter and another 3.5mm, the center of the holes 7.5mm apart. It's obviously easier if you can remove the panel first. I purchased the Lightforce Switch Fascia so I drilled the holes at the center of a knockout switch blank that was included.
6. Once the holes are drilled, place the Remote Head Assembly behind the trim panel, with the Control Knob shaft and LED coming up through the holes. Place the Remote Bezel over your panel covering the LED. Some people skip this step, but I like using the bezel to remind me what level gain I'm currently at (12 o'clock position). Screw the Remote Head Nut on to the Remote Head Assembly. Torque to 0.8Nm. Turn the knob fully counterclockwise. Place the Remote Head Knob on the shaft with "0" in the 12 o'clock position, alligned with the bezel (if you chose to install it).
7. Find a suitable location to mount the Main Unit. You can mount the unit in any orientation as long as it's secure and doesn't move at all. It also needs to be in a location where it reaches both wiring harness and the RG45 cable to the Remote Head Unit. I used an empty hole behind and above the gas pedal in the footwell. I fastened it with a #8-32 screw 3/4" long (could easily use a 1/2" long screw), a 1/8"x1" fender washer, and a #8 locking nylon nut. I just happened to have those lying around, so that's what I used. I don't think you could go any larger of a screw to fit the main control unit, maybe an M4 screw. This was probably the most difficult part for me because there's not a lot of room to work. I also had to use a really small socket wrench to fit behind the hole in the bracket while screwing down the screw.
8. After securely mounting the Main Unit, you can now run the wire harness to the main unit and plug it in. I ran mine behind the fuse box, below the steering column and dropping down to the Main Unit.
9. Plug in your included RG45 cable to Main Unit, route it towards your Remote Control Head, and plug it in to the back of the Remote Control Head.
10. Install your Remote Control Unit in its final place and replace all trims.
11. Reconnect the negative terminal of your battery.
12. Pat yourself on the back for a job well done!
The Tow Pro will calibrate itself automatically and takes about 20 brake applications before it's calibrated. Consult your manual for more info!
You can use any cat5 RG45 cable to connect the main unit to the remote head. At first I used a 3' purple cable I had lying around. I then switched it to a 3' flat cable since the switch fascia didn't leave for much room, and while it could have worked, I decided to use the flat cable to leave more room for possible wiring projects. The 3' cable left me with about 10" of extra cable at the main unit to the fascia. I bought the cable here ($0.89!):
https://www.monoprice.com/product?c_id=301&cp_id=30102&cs_id=3010201&p_id=9547&seq=1&format=2
Update: Had zero issues after install and the REDARC Tow Pro Elite works just as expected. Trailer brakes are applied in proportion to the truck's brakes and trailer brakes can also be applied by pushing down on the REDARC Remote Assembly button. LED gives visual feedback on braking power applied. Have towed three different trailers with brakes, including an almost 1000 mile trip to and from the Grand Canyon from Southern California with no issues.
Happy Towing!
Great pictures, but what about the CHMSL connection? Any pictures or suggestions for that connection?
Edsel
No pictures, but be prepared for a major PITA getting at the connectors and plugging them in. Here are some hints, use at your own risk :shock:
[HINT #1] Previously someone suggested doing it from the bed and removing the entire lamp assembly. That is what I did and I think it was a better approach than doing it all from inside.
[HINT #2] After you determine which 'color' connectors you have, be very careful assembling them and plugging them up. They need to make a snap and if not you may not have a connection. If you cannot get them to snap, push them in hard with a needlenose pliers.
[HINT #3] I was waaaaay too gentle with the headliner after some a*hole said that it would bend, crease and never look the same. After playing around with it I found it to be extremely flexible, it snapped right out and then snapped back in and looks like it has never been out.
mrgary321
Gary
retired engineer
Thanks for the reply! Sounds like a lot of trim removal, but oh well. I just ordered the kit from Livittown Ford and saved $50 over what my local dealer wanted. Anxious to see the directions regarding running the wire to CHMSL. Hopefully all goes well and I don't create squeaks and rattles!
