Red Warning light on the dash when at highway speeds with the adaptive cruise control on.
ChiefQM
Bill
Hiram, GA
2019 Ford Ranger XLT
I have seen, very briefly (too brief to get a photo of it), a red warning light on my dashboard just above the P R D S shifter display, to the right of the seatbelt/0 light and left of the outside temperature display. This light does not illuminate when the ignition is turned on like the other warning lights. It resembles, as best I can recall, a pair of gears with either a wrench or an exclamation point in between the gears. In all the instances, I was on flat terrain, in 2H, traveling about 70 - 75 mph with the adaptive cruise control on. The light goes out after about a second. There is nothing in the manual about this light, and no threads on this forum mention it. Any ideas what it is trying to tell me?
EJH
Ed
Subarus, 2021 Ranger
Is it the TPMS light, that is an exclamation inside a tire that could easily look like a gear?
ChiefQM
ChiefQM
Bill
Hiram, GA
No, it is a red light. I have looked online in various sites but have not found anything like it.
Reactions: EJH
rang19ca
Chuck
Carpinteria Ca
Retired Diesel Mechanic
Can you check for any codes?
LawnMM
Rich
'23 Ranger Tremor
It's the collision alert, look like this?
You'll get it if somebody switches lanes abruptly in front of you and kicks the collision ? alert into action, even if it doesn't alarm if it sees you coming up on somebody too fast, say somebody merging in on an on ramp and it brakes to slow down and maintain your preset distance that indicator lights up and I'm quite sure it's red
ChiefQM
ChiefQM
Bill
Hiram, GA
That is possible, as I haven't gotten a good look at it, but this doesn't occur when I am close to a vehicle ahead of me. I get warnings from the collision alert system (but no braking action) by way of a large rectangular warning in the center display of the dash. I am wondering if it has anything to do with short periods of manual acceleration while in adaptive cruise control, like if I put my foot in it to go around somebody.
Hmm, could be your Brake System Warning light…
If not, here’s a bunch more to consider…
  1. Fog light (front)
  2. Power steering warning light
  3. Fog light (rear)
  4. Washer fluid low
  5. Brake pad warning
  6. Cruise control on
  7. Direction indicators
  8. Rain and light sensor
  9. Winter mode
  10. Information indicator
  11. Glow plug/diesel pre-heat warning
  12. Frost warning
  13. Ignition switch warning
  14. Key not in vehicle
  15. Key fob battery low
  16. Distance warning
  17. Press clutch pedal
  18. Press brake pedal
  19. Steering lock warning
  20. Main beam headlights
  21. Tyre pressure low
  22. Sidelight information
  23. Exterior light fault
  24. Brake lights warning
  25. Diesel particulate filter warning
  26. Trailer tow hitch warning
  27. Air suspension warning
  28. Lane departure warning
  29. Catalytic converter warning
  30. Seat belt not on
  31. Parking brake light
  32. Battery/alternator warning
  33. Parking assist
  34. Service required
  35. Adaptive lighting
  36. Headlight range control
  37. Rear spoiler warning
  38. Convertible roof warning
  39. Airbag warning
  40. Handbrake warning
  41. Water in filter
  42. Airbag deactivated
  43. Fault problem
  44. Dipped beam headlights
  45. Dirty air filter
  46. Eco driving indicator
  47. Hill descent control
  48. Temperature warning
  49. ABS warning
  50. Fuel filter warning
  51. Door open
  52. Bonnet open
  53. Low fuel
  54. Automatic gearbox warning
  55. Speed limiter
  56. Suspension dampers
  57. Oil pressure low
  58. Windscreen defrost
  59. Boot open
  60. Stability control off
  61. Rain sensor
  62. Engine/emissions warning
  63. Rear window defrost
  64. Auto windscreen wiping
ChiefQM
ChiefQM
Bill
Hiram, GA
  3. Fog light (rear)
  4. Washer fluid low
  9. Winter mode
  12. Frost warning
  33. Parking assist
  39. Airbag warning
  41. Water in filter
  43. Fault problem
  49. ABS warning
  51. Door open
  52. Bonnet open
  53. Low fuel
  55. Speed limiter
  59. Boot open
  61. Rain sensor
It is a relatively small red symbol. Not one of those.
Possible Symbols: as a ref only that are red, that have the (!)
Note this is just via Google, since this is an oddball and a way to pinpoint what it is.
Brake Warning
Transmission Fluid Temp
Well, if it’s not one of those, it has to be the Ford version of this…
I hope you figure it out.
ChiefQM
ChiefQM
Bill
Hiram, GA
How about this one
It is definitely red. I will keep a camera handy for the next time it happens. I suppose there is no way to get the OBDII codes without a scanner...
ChiefQM
ChiefQM
Bill
Hiram, GA
Brake Warning
Not it.
Do you drive in Select mode and shift gears “manually” using the +/- button? My thinking here is that if you are, maybe it’s a warning to shift gears. Just a guess.
You know I’m not going to get any sleep tonight if this doesn’t get solved. ;)
