Rear leaf springs for 2wd?
_Ian_
Ian
Tallahassee
2019 Ford Ranger Lariat 4x2
Commercial Real Estate Management
Does anyone know of any rear leaf spring upgrades that work on a 2wd? The OME and ICON kits I’ve found say they are for 4wd and stage3 says they can’t confirm if any will work on 2wd. I permanently keep a couple hundred pounds of gear in the bed of the truck and the factory leaf springs have pretty much gone flat. Would love to increase ride quality and get of the squat if possible ?
machinist85
n/a
n/a
From what I understand the suspension on the 2wd and the 4wd are the same.
Ford only list different part numbers depending on the cab syle.
Crew Cab leaf spring: KB3Z-5560-C
Super Cab leaf spring: KB3Z-5560-D
Some of the aftermarket leafs will do fine like the APG Springs as they keep close to stock height and can increase load capacity. For icon I can't say as I dobt know. For OME you are best not to as the standard spring will lift the rear by 1.6 inches from factory height. That will look pretty goofy if you ask me lol.
GitRDone
Andrew
Orlando Fl
2020 XLT
Real estate management
How does your truck sit with the 200 lb gear out? Wondering if Ford hiked the rear on purpose to compensate for normal settling over time?
When I first got my Ranger (2wd), the rear end seemed comically high relative to the front, but it looks more balanced now. Whether the change happened on the truck or just in my brain, I like it much better now and am glad I waited.
_Ian_
_Ian_
Ian
Tallahassee
Thanks for the replies guys. I have an ICON 2.5 level up front which initially leveled the truck perfectly. Since then the rear appeared to settle and there was a little squat, so I actually ended up lowering the front about .5”, and now with the gear there is probably another .5” of squat again. Not the biggest deal in the world, but I’d like to get rid of it and be able to raise my front end back up, even if the there may be a little bit of rake afterwards.
When I look under the truck, the rear leafs look damn near flat, and there really isn’t that much weight or abuse going on. Anywhere from 200-250 pounds at any point in time, and the truck sees service roads but no real off-roading. Not quite sure what happened in the rear end.
SOHK_Alumni
Win
Tampa
Glorified Mechanic
Easiest path would be a set of extended rear shackles.
A set of blocks between the spring and axle would come in a close second.
Far more expensive and a bit more difficult would be different springs.
Air shocks or bags are also options.
But yes, even unloaded, the OEM springs are nearly flat.
Oddly, my wife's FX4 has a different rear spring than I've been unable to find in Ford's parts catalog even using her VIN. Higher arch than most.
