Rear Diff Locked On Its Own, Unable To Unlock
Raacerx
Max
Norcal
'24 F150 Powerboost, EX-2021 Ranger Lariat Tremor Supercrew
Engineer / Project Manager
'21 Ranger Tremor, 22k miles, the rear differential has locked on its own and won't unlock. Any ideas?
I've tried the tips in the manual about going back and forward, wiggling wheel back and forth, coasting and trying to disengage, but the light does turn on and off when the button input, but the diff won't disengage.
The diff engaged itself about two blocks from my house after getting off the freeway, at the end of a 3 hour drive down from Tahoe. We did some light wheeling but nothing crazy. I was loaded with the rooftop tent and about 600 pounds of gear.
The diff was not engaged when we exited the forest this morning and I didn't use it this trip, only needed 4HI for some mud and snow. Halfway through the drive home, got gas, no binding. After exiting the freeway in the Bay Area, made a few turns without issue, stopped at a stop sign, and when I went to turn a block later, skurt skurt skurt.
I let it sit for a few hours and cool down, but it still is locked. Each time I leave my driveway, I'm chewing up our top layer of asphalt pretty bad.
Backstory: this isn't the first time the diff engaged itself without my input, but last time it was after some pretty extreme wheeling and getting stuck in the snow and being in 4LO for a few hours with a lot of gear. When we got to the highway, the rear end suddenly engaged after a few minutes even though we were going 55mph and wouldn't disengage until we let the truck warm up for 30 minutes. However I got a Powertrain Malfunction Error then. This time there is no code.
Thank you.
Langwilliams
Langley
Lorain, Ohio
The module that controls it might be acting up. I'd try disconnecting the battery for 15-30 minutes then trying it again. You can also check the fuse circuits to see if one of those has anything to do with it. If there is one pull it for a while an try it then.
Instead of disconnecting the battery I would first disconnect the dif locker at the diff(simple connector). What will this do? It will help determine if the problem is in a module/harness or the diff. I do. Ot suspect the diff but who knows.
It's been a while since I have seen the diagrams but I do not recall a fuse for the diff locker
CO2Ranger
Have you tried hitting it with a hammer?
YaBoiNewton
Automotive Engineer
Why are you still driving it? You're just going to keep tearing up your tires and driveway. Call a tow and take it to the dealer. Shouldn't cost you a penny.
It might take a minute to get parts and repair, but they will have it diagnosed way faster than us randos on a forum. Seriously doubt this is any kind of mechanical issue and the techs at the dealer will have all the tools needed to figure it out.
Glocker
Boca Raton
I would first see if you can disengage it by unplugging it at the differential. If it disengages, it'd be better to drive on the road, and I wouldn't drive it at all on paved surfaces locked. From there, I'd get it to the dealer to diag what jacked up!
Raacerx
Raacerx
Max
Norcal
Thank you everyone for the suggestions. Pulling the fuse or disconnecting the harness does not change anything, it seems to be mechanically stuck.
I've noticed some gear oil lightly weeping from the diff fill hole too; maybe not concern, but wasn't there few weeks ago.
To note, my tires are original, pressure is equal, and tread depth is even.
Whether it's coincidental or not, the last time the diff didn't unlock was in the EXACT same place that I was camping this weekend... However, it locked up 5 minutes after getting on the highway, whereas this time it was 3 hours later. But both times we were camping at 7000 feet.
This was one of the next things I was going to try. Going around the pumpkin and hitting it with a hammer while in the air.
Glocker
Boca Raton
By any chance, did you have any water crossings on your trip?
Raacerx
Raacerx
Max
Norcal
As a matter of fact, yes, a few 3 foot or so water crossings.
I'm not actively driving it, but I was trying to see if it was unlocking after various procedures like letting it sit, etc. I can't leave the truck on the street because of parking rules, so each time I've tested it, it involves going down the driveway. =(
I'm simply trying to get it to unlock so I can drive it to the dealer an hour away or at least to my primary home that's closer to the dealer. I'd rather not deal with towing if I don't have to, it's a hassle.
CO2Ranger
You gotta drain the fluid. You're probably contaminated. At 3ft youre above the breather tube I would imagine.
Glocker
Boca Raton
Hmmmm. Yeah, with possible water intrusion, I'd say get the rear diff. cover off to drain it, clean it out (brake cleaner?), reassemble and refill it. I've done water crossings like that before and haven't had any issues, but I may have just gotten lucky!
I would pull the top plug on the diff. If it filled with water you should see all that come out first and then some diff fluid. If there is water then as others suggested get it cleaned up well and then refill after popping the cover back on.
Raacerx
Raacerx
Max
Norcal
Sigh, you've maybe got a point; I didn't really consider this to be a likely possibility simply because <slowly looks around to see if any Ford employees are watching> I've done a lot of way way worse crossings before, without any apparent issue at the time...
However, I did do a wild crossing during our big storm earlier this year, didn't have a choice, water was at the grill so I had to block off part of the airbox, and I've only put about 1500 miles on it since then.
Dont tell them you have been driving it this way , act like you dont know what the hell its doing , admit to nothing while scratching your head...
100%. This is also another reason why I wanted to diagnose as much as I can, before I take it in. I planned to remove the racks and tent and potentially the downpipe.
I know I am a closet case for Ford and the Ranger. I've had the unique opportunity to put thousands of miles of trails on the truck, but I carry about a half ton of gear with me, I've got a tune and downpipe, big front bumper, wind resistance, and a heavy foot.
