Rear Camera
Too bad they won't switch between several cams on a single display. Or a multi-cam display.
I know right? I'd prefer one large monitor with switches to 20 cameras ?
My son got a rear view mirror that also has camera views built in. Hit touch mirror and camera comes on. One forward and one for the rear. He mounted camera inside looking out back window of his F150. Hi def too! I was looking it over in amazement. Problem for us is it deletes our mirrors and dim function but.... Got to think there is an aftermarket mirror that has same functionality and dimming that would be a plug and play for us.
t4thfavor
Chance
Ford has mirrors with camera screens and auto dimming built in. I’m sure there is something someone could do to make a junkyard pull work with an aftermarket camera system.
r1ch999999
Rich
Nashua, NH
Software Engineer
The Camaro SS has another camera in the spoiler that feeds into the rearview mirror. I think it's still against the law to have a camera feed live while going over 35, but I don't know.
t4thfavor
Chance
My camper does it at any speed, plus i've seen some other vehicles that have rearview mirrors that double as camera screens.
Obijack
J J
NE Florida
2020 Ford Ranger Lariat FX4 iconic sliver
Attorney
So the consensus is- there is not way to toggle the rear view camera in any other gear positions aside from reverse in Forscan?
Reading through this thread again I’m now wondering if just adding 12V aux to rear view camera would be enough to get it activated whenever you want it. Seems the way it’s setup now for reverse would say it most likely gets triggered by backup lighting. So it would stand to reason if that’s true then just supply alternative power would do the same thing
t4thfavor
Chance
Just piggyback a momentary switch to in parallel to the reverse switch in the shifter mechanism. It should activate when that switch closes.
myothercarizahearse
Cleveland, Ohio
Unretired
where did you the "triggered by backup lighting" and where are schematics I might give it a go. might even be a switch on the shifter and that would make it easier
edit: little slow
edit: little slow
Camera has to get power from somewhere right. Only thing back there with it that is in sync is backup lights on the tail lights. Same harness. Just reasoning it through. I highly doubt there is a separate feed just for the camera
t4thfavor
Chance
Camera is powered all the time, the input change is triggered by the reverse switch almost guaranteed (because it comes on while doing 70 on the expressway if you put it in reverse).
myothercarizahearse
Cleveland, Ohio
Unretired
I don't have experience with Almighty Ford engineering. have you been in the shifter or seen it taken apart?
THLONE
Thom
Tucson,AZ
internet wise guy
Do the back up lights come on at 70 MPH?
2020FRL
2020FRL
Alan
Grand Junction, Colorado
2020 Ford Ranger Lariat, 2014 Harley Tri Glide
Now that might come in handy for tailgaters ... ya know ... if you don't have a damper installed ... :blush:
That’s a future option. Lighted damper sign tailgates. Message will display ā€˜get off my ass’ or in turbo mode ā€˜have a nice day!’ Just be patient, it will come eventually ?
