Rear blocks self detonated!
ScarzRanger21
Auberry
electrician
Was sitting at a red light on my way home from work. Hit the gas when it turned green and felt the back end of the truck slam. I thought someone may have rear ended me. Instantly started hearing a god awful popping noise and thought for sure my transmission just exploded...
Pulled into a parking lot and found the rear lift blocks had failed. One was gone completely, the other had shifted and was pinched between the axle and leaf spring. The noise I was hearing was the tire scraping the fender.
Never seen lift blocks fail like this before. Thankfully it happened at a light and not while I was going 75 on the freeway! Could’ve ended much worse. I don’t remember where I ordered these lift blocks from, it was either Amazon or EBay.
Anyone have suggestions on a 1.5” rear lift? My truck now has the Carolina squat and I look like frat boy ?
Rinn69
N. Central Iowa
Retired USAF MSgt
I'm just hoping you don't buy another lift kit from Amazon or eBay ? :p Any of the reputable companies on here or well known/established supplier should work fine.....anything to get rid of "The Squat".
ctechbob
Shawn
2020 Ranger XL/FX2/STX
Adult Daycare
If your new kit doesn't come with them, you might want to budget for new u-bolts as well.
And some locktite.
ScarzRanger21
ScarzRanger21
Auberry
electrician
Definitely not again! Lol the only reason I ordered them through Amazon/eBay was because 1.5 seems to be an elusive size. I researched a bit before buying and could only find 1 or 2 inch blocks. 1.5 gave the truck a slight rake which leveled it nicely with weight in the bed or when towing my boat.
I learned lessons in the past going with cheap parts when it comes to stuff like ball joints and UCA’s but I didn’t think you could possibly screw up manufacturing a lift block… Apparently I was wrong!
ScarzRanger21
ScarzRanger21
Auberry
electrician
Back in the day we had a saying, “Friends don’t let friends use blocks”. While really it was just giving our buddies crap it has a lot of merit. Icon springs sound like a perfect fit for you. Safer too.
Gonna look into
Looking into those. Can’t decide between medium or standard duty springs… Trying to get the closest to OME springs.
ScarzRanger21
ScarzRanger21
Auberry
electrician
Gonna look into
Oh wait, I see the icon’s are adjustable. That’s cool, might get a set of those.
Ouch!!
My only guess is either the U-Bolts were not torqued correctly(happens more often then not) or the U-Bolts were reused(they are supposed to be replaced).
ScarzRanger21
ScarzRanger21
Auberry
electrician
Ouch!!
Torqued them to 100 foot lbs but did not replace ubolts. Maybe that’s what happened. Wasn’t aware of that…
Yeah, U-Bolts are supposed to be replaced when adding blocks or replacing Leaf Springs. A pain, but what it is.
