Putting on aftermarket intrusion bars
jcru1017
jcru1017
Jeremiah
Glendale, CA
2020 Ford Ranger FX2
Student, Legal
When my readylift intrusion bars were installed, they never removed the bumper. The old ones were cut out, and then the readylift bars have a bit of an angled interior corner so they'll slide in. I found that the readylifts seem very beefy compared to the old bars.
yeah that’s what I read too on the forums. Seems like it’s the better choice
jmurph
jake
Alaska
2021 XLT Ranger
Gov
how did you guys get the rears out with the plastic blocks above the crash bars? my rear crash bars bolts wont come out as they have no clearance to pull out with the plastic in the way?
oubbascooba
Jacob
I’m stuck in this too. I removed the two bolts for those plastic waffle boards but I don’t see how they come off. Without removed those plastic blocks, the inside bolt cannot be extracted. Anyone have any insight?
Hey everyone
I had a question about installing aftermarket intrusion bars.
I understand the easiest way to remove the intrusion bars is to cut them. However, when I install aftermarket intrusion bars (Readylift) does the fender still need to come off?
Because my logic is, if I cut them out to make it easier, wouldn’t it still be difficult to instal them because of the fender, bumper etc. are still in the way?
Thanks!
Hi Jeremiah,
You are changing the crash pulse...and Likely not in a good direction. Ready Lift did not likely crash test the bars to ensure the energy reaching the occupant in the cabin is similar to the Ford bars.
Beefy is not your friend in these cases of crumpling to dissipate energy... Unknown what might be more severe injury... Very foolish mod...JMO.
Dereku
Derek
Chicagoland Area
2021 Ford Ranger
Project Manager
Hi Jeremiah,
Phil,
I do have to ask your opinion on large off road bumpers. The intrusion bars clearly serve a purpose and probably have a specific force they are designed to bend at so I agree with your statement. However would a change in bumper impact the way the frame crumples as well? I think the answer would be yes. Just curious.
Thanks!
Phil,
Thanks!
Hi Derek,
You make a good point that aftermarket bumpers might affect the crash pulse, but the key crumple is the frame which is not changed. I think a bumper mod is less likely to affect crash than the crash bars for side impact protection...
Dereku
Derek
Chicagoland Area
2021 Ford Ranger
Project Manager
Hi Derek,
Thanks a lot Phil. You are a wealth of information. I wish I knew you when I was a teenager with a sawzall, oxyacetylene torch, and a arc welder. Oh those were fun times, it's amazing I didn't die.
Carmell269
Central Iowa
2019 Ford Ranger Lariat FX4
Electric motor mechanic
There are actually 4 bolts that hold those plastic blocks on. Two are hard to see. They are on the outer edge and the bolts are at an angle.
oubbascooba
Jacob
Ahhhh thank you. I didn’t fully pull the fender liner and was wondering what the heck was going on. I’ll dig deeper this weekend. Thanks for the information!
Carmell269
Central Iowa
No problem, glad I could help.
oubbascooba
Jacob
Quick question. Are the side bolts under the fuzzy liner, or actually under the outer plastic fender that the side marker is attached to?
Carmell269
Central Iowa
They are under the felt liner. Kinda hard to get to. I had to take the bottom fender trim screw out and pop off the lower portion of the trim to be able to get a socket and extension in.
Fawnbuster
Indiana
Retired 34 years as LEO
Hey everyone
Thanks!
I cut my oem beams and did not need to loosen the bumper, just some inner fender well plastic liner parts, I also had to trim a hard honeycomb plastic mounting block on both rear portions of my front wheel wells, in order to reach a small deep bolt. I wrote it up on one of my build threads.
The readylift beams are trimmed down to allow tire clearance and easier install but they reinforced the entire bar with an extra center bar to make it stronger.
Here is a link to my install post. I bought the beams at coopscustoms.com. I think that's the correct spelling google to be sure.
https://www.ranger5g.com/forum/threads/what-did-you-do-to-your-ranger-today.3511/post-224377
