RCMUSTANG
- First Name
- Ray
- Joined
- Jan 22, 2019
- Threads
- 22
- Messages
- 1,867
- Reaction score
- 2,191
- Location
- Los Angeles
- Vehicle(s)
- 2017 Fusion 1995 Ranger
- Thread starter
- #226
Pretty sure that feature had been removed.
Hey RC - got the module back yesterday and I installed it this afternoon. Everything works great! Thanks for all the help and fixing the wires I damaged. You’ve been a friend to everyone in this forum!I installed my module this afternoon. Everything works perfectly! I watched t4thfavor's video and used YouknowwhatImean's illustration and it was a breeze, just about an hour start to finish. Big thanks to those two for the installation guide and, of course, RCMUSTANG for making this option available to the group!
I can repin mine, if that'll save you the hassle of at least one.UPDATE: Finally got the invoice for the last order of 10. They should be shipping shortly with the few replacement harnesses. However, they have not be able to get the harnesses for the correct right hand drive ordered. So, I will correct all the harnesses myself this time. If this is the case for further orders I'll have people order directly from them as it's a lot of work to set up group orders, mail them out and correct harnesses.
Still have 3 outstanding payments. One requested delayed payment. Other two have not heard from.
Sure would. But I plan on doing the rest anyway.I can repin mine, if that'll save you the hassle of at least one.![]()
That is a fine wiring job. I was going to shrink wrap mine but it was too hot out. I figure if the taps ever come loose or I have to touch the module again I'll do a better job. I also pointed the port down in case of water.Then I strip away a portion of the wire jacket and twist the desired wire around the exposed portion. I use a quality shrink wrap which produces a clear goop once properly shrunk to make a water tight seal. You could make a quick spot weld with solder, but in my experience its overkill as the shrink wrap will hold the wire in place permanently.
Finally found the time to get mine installed today. I thought I would add some pictures to show hoe I went about it.
I do not mind easy taps and the like, I just don't use them where water may be an issue.
Agreed, if you heat shrink all three wire inputs into the post-tap it would be water tight. Most people use them for a nice, quick tap and if going through the effort to use heat shrink, why heat shrink a posi-tap if you can just heats shrink? No argument here, there are many ways to skin a catposi-taps are pretty 'water proof' from the outset. however, to be xtra sure, just throw some heatshrink tubing over it and Voila.
