Oil found in charge pipe/intercooler
Lampcont44
2020 Ford Ranger
2020 Ranger here
Was replacing the charge pipe going from the intercooler to the throttle body (it was deforming and super soft from the heat cycles) and notice oil pooling at the bottom of the tube. Stuck my hand in the intercooler as much as I could and felt a layer of oil on the walls.
Anyone had something similar happen? Could there be a leak in the turbo/seals?
ctechbob
Shawn
2020 Ranger XL/FX2/STX
Adult Daycare
Likely normal.
F150 owners have been adding weep holes to their CAC's forever now to let oil/water seep out of them. I'm sure someone with a catch can will chime in any time now about saving their intake tract from the horrors of PCV vapors, but a little oil/water in the stream isn't uncommon.
Stevedbvik1
2022 Ranger Tremor XLT
2020 Ranger here
Your turbo doesn’t have seals , instead they have tiny piston rings that have end gaps. They can pass oil if there are other circumstances not related to a turbo issue. Such as a dirty dry or improperly oiled K&N style air filter, restriction in the oil drain tube or higher than normal crankcase pressure. Your turbo can also be ingesting crud from the pcv system and passing it along through the intercooler. It’s most likely the latter and is why some choose to use catch cans. If you wanted to confirm you could pull the intake tube from the air cleaner to the turbo and inspect the cold wheel. Or try snaking a borescope down the inlet to inspect the cold wheel.
Racket
Here and There
2019 Lariat Supercrew 2WD
Transient
Crank case ventilation will do that.
Does that make an argument for the vented oil filler cap? I've considered those but the feedback was they seem to cause reduced fuel mileage - I wonder how?
When the owner of UPR spoke to me about our trucks he took the valve cap off mine while it ran and held his hand over the hole stating that the pressure escaping was evidence of power restriction.
I'd only wonder the pressure in the crankcase was weighted against piston rings or addressed by the second vacuum line I was picking up that day for the catch can (which they branded the WOT option).
yamahaSHO
Greenwood, AR
www.jaztuning.com
No, I would not vent the oil cap. If you're wanting to reduce oil vapors, a GOOD air:eek:il separator is the way to go.
RangerBill
It would allow unmetered air into the fuel-air mixture, so the PCM couldn't control the mixture properly.
Racket
Here and There
Transient
Racket
Here and There
Transient
I think the caps people were installing had a pressure valve for venting only?
It seemed a mod that really didn't catch on.
Dgc333
21 Ranger Lariat
The 2.3 Ecoboost engine uses a speed density control system meaning venting the oil fill cap will not have any impact on controlling the air fuel mixture. However, there is a sensor in the PCV system that measures air flow and venting the oil fill cap will/can cause check engine light and a trouble code.
The questions are -
How much oil was pooled in the bottom of the tube? more than a tablespoon?
Is there oil pooled at the compressor outlet?
RangerBill
Thank you for the correction.
Lampcont44
Lampcont44
2020 Ford Ranger
The questions are -
I'd say it's about a teaspoon. I didn't check the compressor outlet but if I have time I can check it this weekend.
A small amount is normal, but the tube deteriorating was my question (what caused it?) Excessive Oil?
