Oil change 3,000 or 5,000 miles?
Dave1899
2019 Ranger Supercrew Lariat 2WD
Retired Living the Life
I have about 3,200 miles and I keep getting "Urgent - oil change past due" The service guy said I didn't need to change it until 5,000 miles. Is this true and if so how can I turn off the warning message?
I would do it at no less than 5k. A lot of people go longer. Any less than that is a waste. I do it at 5k with tire rotation. I don't like rotating at more than 5k.
I forget the warning turn off, pretty sure it's in the owner's manual.
slowmachine
New Hampshire
Are you saying you have only 3200 total on the odometer, or 3200 since the last oil change? The dealer failed to reset the oil counter on my last change, so I’ve received a couple messages from the Ford app.
Dave1899
Dave1899
3,200 total miles on the truck.
Jrel209
Wa
2020 Ranger XLT crew cab
Since Its a DI engine and its almost guaranteed you’ll have carbon buildup on the valves. And not sure why/how but every article i find says to do regular oil changes to help minimize it, there ase other things but changing oil is the most common. Id rather NOT do it over 5k miles.
2020XLT
George
Eden, NC
2020 Ranger XLT, 2015 Ford Edge, 1966 Mustang GT
GE Healthcare FSE, Retired
Go to the oil change reminder notification screen and reset it to 100%, then either change your oil or wait to the 5,000 mi mark. My local quick oil change place resets it during the oil change. I have 20,000 miles on my 2020 XLT, I have oil changed every 5,000 miles.
I do the same even though they say you can go 10K. I get my tires rotated at the same time too and with our high heat it's cheap insurance.
slowmachine
New Hampshire
Because the dealer failed to reset my oil life monitor, I’m at 7% oil life remaining with 850 miles to go before I hit 20,000. My climate and usage are less severe than just about anywhere, so I’d bet you would run out of oil life on the GOM before you hit 10k anyway.
Yeah NH is a great state and I've spent quiet a bit of time there when I lived in MA. Most of the time my oil life is at about 40-45% when I change it which is surprising. Also I don't run it hard in the summers with the heat but this time of year with the crisp cool days it screams. ??
Dave1899
Dave1899
Thanks, I fixed that problem!
Dave1899
Dave1899
JMO 1st oil change at 500 miles. After that 5k because I run Castrol Full Synth.
Is a 500 mile change even necessary in this time and age? That sounds really old school.
BrassSlinger
Rich
Western North Carolina
2022 Velocity Blue Tremor Lariat,2017 Honda Civic
Technician
I do early oil change on every new car/truck i buy.Usually at @2500 miles to get the metal shavings out.Same with the dif
Langwilliams
Langley
Lorain, Ohio
500 isn't enough IMO. I'd go 2K-2500 to give the moving parts time to break in an get the gunk out. If you drive a super low number of miles you might want to change it every 5-6 months even with low miles. I do mine 4 months or 5K. The only way I'll break 5K in less than 4 months is if I travel somewhere during an oil period.
A Tale Of Two Rangers
Huntington Beach
2021 Ranger XLT 4x4, 1999 Ranger XLT 4x4
Marketing
In inherited a 4.0L 1999 Ranger XLT 4x4 with tow package and automatic trans. from my younger brother. He changed the oil every 3,000 miles. the truck now has 270,000 miles and the engine still makes over 9:1 compression in each cylinder. My brother was sort of compulsive about service and even kept a log book with every fill up, oil change and service.
The cost of an oil change compared to the cost of the vehicle seems like cheap insurance. I have continued the oil change regimen since inheriting the truck in late 2013.
