Factory Tow Package - Settings
VainoN
Vaino
NEW JERSEY
2020 Ford Ranger XLT FX4, Factory Five Cobra
Tech Management
For those with Forscan and the Factory Tow Package, can you tell me what your setting is in APIM & IPC for Trailer? I installed the Factory/Redarc unit with the Factory Hitch. However, when I look at Forscan I see a few of the settings set to disable. This may be correct. I'm wondering if this is something the factory would have changed when factory installed, and something the dealer would be changing if they installed. They may only be for F-150's, etc., but I'm double checking.
Namely:
IPC / Trailer Tow Backup Assist = Disabled
IPC /Trailer Reverse Guidance=Disabled
APIM / Trailer Tow Backup Assist = Disabled
APIM /Trailer Reverse Guidance=Disabled
Your input might help others who are doing Post Factory installation of the Tow Package. :)
Namely:
None of those setting have anything to do with our Rangers. There should be no Forscan changes required after installing the Ford/Redarc brake controller.
VainoN
Vaino
NEW JERSEY
Tech Management
What I expected as the "Backup Guidance" and "ProTrailer Assist" are physical packages added to the F series. I thought it was worth the ask. :)
