Need a left side CV axle
rydfree
Benny
Maintenance
Well I've had bad luck since getting the 2020 a few weeks ago . Leveled her out then went to get alignment and the rear bumper was damaged . Parts on backorder for that so just in a holding pattern to get repaired . Today the drivers side CV started clicking and is leaking grease badly . Have been driving OK since the level kit was installed but I know this was my fault so just took to mechanic to get repaired on my dime . NO part to be found anywhere , Uggggh ! Most places say national backorder until at least Oct 20th and then it's a matter of how many orders are in front of mine :(
If anyone knows where to find a new or used drivers side front axle for a 2020 crew cab FX4 Lariat Ranger please let me know . I can find several for 2019 or even a 2020 XL/XLT but they all tell me they will not work on the 2020 Lariat .
I had watched this video but did not read the comments about they were doing it incorrectly . I came back in and re-watched it after the drivers side was so difficult and realized you should remove the axle nut first to prevent putting stress on the CV joint . The right side went very easy . They should really take this video down and I should have actually realized the issue sooner myself .
Dustin
2019 Ranger XLT Sport 4x4
I wish I could contribute something to your thread, but I will tag along and see how this goes for you. Rock Auto shows the same part numbers between 2019 and 2020. BUT only available in XL/XLT like you said.
MattS
Matt
Santa Cruz Mountains
2020 Ford Ranger XLT Fx4
Brutal. I dislocated my driver side when installing new suspension. Big bummer. I was told this is a dealer only part. I had to call a couple dealers before one located the part at a different dealer. I'd call a ford parts department and see if the can find one. Once I got it the install was easy. Should have just removed the damn axle nut!
I feel for you Benny - I was fortunate enough to find the threads that warned about the axle nut before I did my level. I was so paranoid, I actually pushed the axle through the hub and zap strapped it to the anti-sway bar link. ?
Because the calliper and rotor are so heavy, I pulled them after first wrestling a bit with them attached - it was ten times easier to manipulate when putting it all back together. ??‍
Like @Mustang2Ranger says, get in touch with Benny @LevittownFordParts.com - if anyone can help, it’s him.
AdamHarris
Adam
Blue Oval City, TN
Collision Repair Instructor
I dislocated my cv axle as well installing my 2.5 spacer lift (learned the nut Must come off). by some sorcery miracle I was able to pop it back in place and finish the install.
rydfree
rydfree
Benny
Maintenance
Thanks guys . I'll try to get in touch with the other Benny , maybe he will have some sympathy for a fellow Benny , LOL .
I'd like to know what the difference between a Lariat and the XLs are . Doesn't seen to make any sense . There also must have been a re-design of the CV shaft from 2019 and 2020 also as a couple I found for 2019 models they said would not work.
Sorry to hear about this Benny. Maybe @Stage3Motorsports can help out or possibly help point you in the right direction? I hope you get it fixed soon....Good luck!
rydfree
rydfree
Benny
Maintenance
Don't think I'll be asking Stage3 since it's their video that causes a lot of folks to do it incorrectly .
Doh! Sorry I had a brain fart from the first post. :headbang:
rydfree
rydfree
Benny
Maintenance
Call Levittown ford and tell your story/ask. Talk to Benny and let him know you are from the forum
They specialize in parts and may be able to locate one or direct you to a used one
I tried Levittown Ford and he said backordered until mid November :(
