must mods with forscan ?????
redone17
Cold Spring, NY
2021 Bronco Black Diamond, 2020 Ford Ranger Lariat
I believe we may be on to something. The As-Builts would have the original defaults. - Of course, if I roll it all back (assuming I could even do that), I would just have to redo all of my previous updates again. Might actually be less of a pain to do it that way, quite honestly, than hunt and peck.
On a completely different side note; I accidentally discovered that the Factory settings were incorrect for the stock tires. Anyone out there with a Lariat having the Hankook 265/60/18 will likely have 2356mm as the stock values. This is actually for the 17" rim and not the 18" rim, so your speedo and MPG reading would slightly be skewed.
No shit. Really? Now I have to test with the GPS. Assuming that number is too small - compounded that affects mileage too. Funny, it was advertised as LOW MILEAGE at 28k for a 2020.
Waltztj
Walt
2021 Ranger Xl
FWIW, I saw this thread pop back up, so I found my spreadsheet with my changes:
SettingDescriptionModuleAS-BUILT CodeCreditAction
Climate Seats on Screen, called seat icon buttonAdds seat heat control to Home menuAPIMTurned ON
Corner Light Mode for Fog LightsTriggers fog light based on steering input (left vs right illuminated)BdyCM (BCM)Gfitzge2Turned ON
Double Honk on Leaving CabineDisables the double-honk when closing door with key in.BdyCM (BCM)726-41-02 (xxx0 xxxx xxxx)Gizmokid2005 / j0shm1lls (AS-BUILT)Disabled
Fog lights if High Beam is on (AKA - Bambi Mode)Allows the fog lamps to stay on when the high-beams are used.BdyCM (BCM)726-27-01 (xxxx xxx0 xxxx)Gizmokid2005 / RCMUSTANG (AS-BUILT)Turned ON
Navigation in MotionSpeed limit signs will look European and FM radio stations will be 2 decimals (101.70 vs 101.7). 911 Assist will be disabledAPIM7D0-02-01 (5753 xxxx xxxx)John GaltNot present
Panic ActivateChanges behavior of Panic Button behavior on KeyFOBBdyCM (BCM)726-37-01 (xxxx xxx# xxxx)Gizmokid2005 / AS-BUILT info uncreditedTurned ON, option 1
0 - Panic on FOB Disabled
1 - Panic on FOB requires 2 presses
2 - Panic on FOB Enabled (Default)
Secure IdleTo idle the car with the key not in vehicle, cannot shift from park)BdyCM (BCM)726-42-01 (x1xx xxxx xxxx)John GaltAlready set ON
Software anti-noise controlACMTurned ON
Software Engine Sound EnhancementDisables the "piped in" sound through the speakersACMGizmokid2005Turned ON
Any chance of getting the excell file uploaded?
kendive
Ken
23 Ranger Lariat Tech Pkg Tremor
I owned my 23 Ranger for about an hour and hooked up FORScan to change Disable Double Honk, Disable Auto Start/Stop, and Turn Bambi Mode On.
I will probably do more changes sooner or later.
Tom_C
Virginia, USA
System Admin, Retired
The one I have is limited to what I have done, and I created it from the list posted in the stickied wiki post. You should be able to copy the entire list from the wiki and dump it into a spreadsheet, that's what I did, and then removed everything I wasn't interested in. My spreadsheet only has a very few lines of the extensive list in the wiki.
ADDED: I just tested it again to be sure... Go to the Wiki, highlight all the rows/columns shown, copy. Open excel, go to the first cell, and paste. It will create a new spreadsheet with all the rows and columns formatted. Then, just edit how ever you wish. I added a new column at the end for "action", which tells me either how the setting was when I found it, or how I changed it to my preference.
IRISHTREMOR
Swartz Creek, MICHIGAN
2021 Ford Ranger Tremor
Bulk Ammonia Hauler
I could’t bring myself to remove the OEM fog (driving?) lights. So I just added the DD to the middle opening in the bumper. ??
Can I ask what brackets you used to mount? I was going to put a light bar there but realized I couldn’t with adaptive cruise.
Danager
Dan
Alberta
2019 Edge
Manager
I made my own bracket. I do t have great photos.
I used 1”x1” aluminum angle. I attached a vertical piece to each of the bumper mounts. I then attached a horizontal piece to those vertical pieces.
under the lip of the front bumper where the lp holder goes is two small holes that go into the plastic but also through the steel of the bumper. I used those to put mounts in the past. worked well. no drilling.
shovelhd
Cape Cod, MA
2021 Ford Ranger Lariat
retired electrical engineer
I just finished my first round of changes with Forscan. $59 later and all of my known annoyances are gone.
Auto Relock Time Duration to 45 seconds
Chimes - Belt Minder disabled driver, passenger, middle
Chimes - Vehicle Running Door Open disabled
Disable Startup Chimes
Disable Honk on Leaving Cabin
Bambi Mode
Panic Activate to 2x press
Radio Without Ignition Switch to 45 minutes
Secure Idle (checked, was enabled by default)
Software Engine Sound Enhancement disabled
It's a start. Forscan isn't as sophisticated as the VAG VCDS but it is just as powerful and dangerous. The Forscan threads, as well as copious notes and pictures, will minimize the risks.
Deleted User 38384
I just did my 1st Forscan "thing"...
BAMBI MODE - Enabled
It has officially paid for itself.
So next question is,,, what other cool shit should I be changing next ?
What are the coolest Forscan mods ?
There was already a lengthy thread on this so I merged it for you. :wink:
Deleted User 38384
I cannot find the path to change the Software Engine Sound Enhancement.
My software doesn't show a ACM as built module.
I also noticed something that got me drooling,,, Launch Control !
...which I'm assuming doesn't do anything for our Rangers. Or does it ? Has anyone F'd with it ?
Oh... it is so nice without all those senseless chimes.
