Mixing Eibach Pro-Truck Front / Bilstein 5100s rear
JimInAllen
2021 Ford Ranger STX SuperCrew 2WD
Cybersecurity Consultant
Anyone mix Eibach in the front with Bilstein 5100s in the rear?
My backorder just updated from September to 11/17/2021 on the 5100s, so I'm looking at getting the Eibach's for the front as the 6112 are just a bit too much for me. It's either that or put Bilstein 4600s on front while I can still get those and a spacer.
Thanks,
Joeiconic
Dude, you are on a mission!
kieefer
keith
Oh gawd, I guess the next thing we will be mixing is tires. Jeezz, this world has gone to pot.
JimInAllen
Since I replaced the rears, I'm noticing the front much more. Thinking I'll put on a set of 4600s. The freeway I drive to work is pretty "floaty", and I was really noticing the bounce effect with the stock shocks.
ctechbob
Shawn
2020 Ranger XL/FX2/STX
Adult Daycare
FWIW other than the adjustable perches, the 4600's are the same valving as the 5100's. Had I known that before I bought the 5100's for the rear of mine I would have done 4600's all around, but as it stands now, when I get around to doing my front's I will have 4600 on the front and 5100 on the rear as I'm not interested in leveling the truck.
SPEEDBUILT
Zak
SacTown
2020 Ford Ranger Lariat FX4
Strength Coach
Don’t do it.
Alpinist
Scott
Seattle, WA
2019 Ranger XLT Sport
I'm confused why everyone is running Bilstein 5100's in the rear, if only leveling the front. Wouldn't the 4600 be the correct choice for the rear at stock height (i.e. no lift block or leaf pack)?
Deleted User 61245811
I believe the 5100's will give you the option, should you choose some time in the future, to add up to a 1" block lift in the rear. The 4600 rears would require that you stay stock height.
JimInAllen
I ended up finding a new set of Eibach Pro-Lift shocks and the 3in Eibach front springs,, as the fronts for the 5100s are detailed until 11/22 (?).
Langwilliams
Langley
Lorain, Ohio
I did the opposite....I run Eibach's on the rear an Bilstein's on the front. Rides an handles fine to me.
Alpinist
Scott
Seattle, WA
Gotcha. I wonder if there's any issue with bottoming out the shock if the truck is at stock ride height with a load in the bed when running the 5100's.
Stage3Motorsports
Joel
Phoenix Arizona
2019 Ford Ranger 4x4 XLT CrewCab
Sales Specialist
Did you order the eibach's? inventory on those are currently sparse as well.
If you ordered bilsteins from us feel free to shoot me a message.
