Long Travel Setup
Superdannyboy
Superdannyboy
My stock OEM ball joint ends appeared to be maxed out at full droop with the ICON 2,5" Ext travel coilovers....the extra range of motion of the APG's fixed that...now I think the stock sway bar still attached is my droop limiter....Beside the advantage of less binding, the up graded tie rods are holding their toe angle alignment better...
Yea I'm sure the steering's going to feel much tighter and holding that alignment alone should be a reason to get upgraded tie rods especially with 35's or bigger. Sway bar? What is that? Lol
Superdannyboy
Superdannyboy
Can't wait to put these on tomorrow and take it in for an alignment. My last alignment didn't last too long, wel my wife drove the truck once and ever since then the steering wheel has been off ??
Superdannyboy
Superdannyboy
Bad news. So first to understand the situation you have to understand I am running +3" wider control arms and the kit came with 3" spacers that screw between inner and outer tie rods. I couldn't get the spacer loose so I dropped off the truck and the new tie rods with my mechanic because I figured my wrenches were too small to get good leverage. He messaged me that the spacer seized and broke when trying to take it apart.
I'm waiting for APG to call me back to buy their extended length tie rods.
I thought the new outer tie rods were supposed to work with the factory inner tie rods?
Superdannyboy
Superdannyboy
Just got the extended length tie rods from APG overnighted. My truck will be ready for me by the time I get off of work tomorrow.
Got some SVC tie rods for sale!
Superdannyboy
Superdannyboy
Extended Length? ...I have the APG stock length Billet Tie rod ends with the Heim joint end on my "mid runner"...APG has an extended length Billet Tie rod with the adjustable end for the " Pro-Runner:" long travel , allowing for more than 3,0" used in that kit..
Whiplash wya??
I ordered these in extended length!
Honestly when you posted this picture I was like damn I should've gotten the extended length and now I did!
Superdannyboy
Superdannyboy
Can you post a picture of the tie rods on your truck?
Whiplash
Kern
The southwest Missouri Ozarks
2021 Ranger XLT FX4 / 2004 Mazda RX8
Not sure what you needed to see..pictures are of driver.side with wheel turned out to full lock position....My alignment guy is across the street from an offroad shop that specializes in extreme suspension set ups...He is very familiar with Heim joints and it still took him several tries and test drives to get the steering wheel centered to his satisfaction...He made the comment that Heim joints are "tricky" to get adjusted properlly...
Not going to lie.... I was hoping that you would have a picture of them simply laying on the hood or something just for the fun of it!!
Superdannyboy
Superdannyboy
I never got to actually hold mine they went straight to the mechanic to put on. I would've put them on myself if I knew I was going this route. When I tried, the spacer was seized in the stock outer tie rod.
Whiplash
Kern
First picture of when I received them in the mail Dec. 10th 2021...I did the install within days....2nd picture April 1st 2022 my first post showing them on the truck..
Proof that you missed a great April Fools joke right there!!
Whiplash
Kern
The picture was posted in the build and project forum..."Whiplash, 1st year of mods" ... which I started April 1st 2022, to show what I had done to the truck in my 1st year of ownership...just coincidence that I did it on April Fools day...was not trying to deceive any one....?....
Superdannyboy
Superdannyboy
Got my tie rods installed and my alignment but the mechanic said I need to replace my upper control arm bushings because they have play. Got some at home that I ordered from Dirt King.
