List Of Deleted Items
Figarou
No, it was a little breezy so it got a blow dry. Clean engines are much easier to work on.
And I know some are squeamish about getting the engine wet but I've been doing that forever. I'm not using a pressure washer or even full pressure out of the tap, not soaking it, just a shower to rinse the dust and splattered mud. Only cars I ever had issues with were when they had old plug wires and that was resolved with wd40. :like:
I rinse my engine as well. I like using the Master Blaster so I won't see water spots.
And yes...I'm careful on how I use it to dry the engine.
DakotaGuy
Tom
Black Hills, SD
2022 Ranger SuperCrew XLT Tremor
I posted this earlier, but mine was built in March of '21 and they're aluminum. Did it start in April?
Sorry I missed your post. If yours was built in March of ā€˜21 and another poster says his are steel built in late April ā€˜21 that means Ford probably decided to play an April Fools’ joke with the fenders and they weren’t joking!
DakotaGuy
Tom
Black Hills, SD
He
ca
I’m adding hood struts to mine so I’ll have dual hood support capability. Just in case. But for the right price I’ll let the prop rod go
I’m sticking with the prop rod so I can be the cool kid and tell people to stick my rod you know where if they piss me off. (Just kidding…. Please don’t ban me mods):wink::crackup:
Stevedbvik1
2022 Ranger Tremor XLT
I heard the Tremor’s hood rod is painted red to match the nostrils.
DakotaGuy
Tom
Black Hills, SD
As a sign of revolt!
Yes! My first car in high school was a 1993 Tempo. It had a prop rod for the hood. If a prop rod was good enough for the Tampon (what my buddies called my car) it’s good enough for my new $45k Tremor.?
FordFreak
2020 Lariat FX4 Ranger, 2022 Sonata Limited
My 2020 Lariat seats don't have the embossed RANGER thingie on the seats either. My kiddo's 2019 does. I'm fine with that. I have all the other shit.
NCRANGER
2019 Lariat Super Crew FX4
Retired Electrical Engineer
Weren't front tow hooks deleted on the 4x2?
Yes, missed that one...They were deleted on XLT & Lariat non FX2 4x2 models in 2021. XL never had them on 4x2 as far as I know. I'll update the list!
My '21 Lariat has the glove compartment light. You're spreadsheet shows them being removed in '20 some time?
Typo, thanks for the input. I believe it was removed in MY22.
Updated list attached.
DakotaGuy
Tom
Black Hills, SD
So I sort of found out the deal on the steel fenders. Earlier 2021s are still aluminum and once Ford ran out of them in the Spring of 2021 they switched over to steel. The weight difference is very minimal like a few pounds at most. The big difference and likely cost savings besides the material is Ford is stamping the steel fenders in house. The aluminum fenders were being purchased from a supplier. Anyhow that's the deal on the front fenders.
DakotaGuy
Tom
Black Hills, SD
Here is one more delete for 2022. This might be a positive depending on your gauge cluster preference.
(2) 4.2" productivity screens instrument cluster replaced with (1) 4.2" productivity screen instrument cluster in Lariat 500A.
So basically they gave the 500A package the XLT cluster.
Now you see why I am so doubtful that all digital gauges across the line are coming with the 6G in North America like they are overseas.
Canuckian
Canada
2022 Ranger Crew Cab Lariat Blackout
Regarding all of the ā€œdefeaturedā€ aluminum parts. We are/were on the verge of a global aluminum shortage, prompted by a world magnesium shortage out of China, so I suspect switching away from aluminum to steel where possible was a supply chain risk management decision. It was thought the disruption could bget so bad that it shut down most vehicle manufacturers due to lack of parts.
also, some of the other ā€œdefeaturesā€ like hood struts are probably due to shortages rather than cost saving. This is evident in the challenges buying struts in the retail market also.
R
Regarding the hood prop, does anyone know if the lower trims came with props originally, and they just expanded that to the full lineup? I doubt the made a new part the the hood prop and cowl specifically.
DakotaGuy
Tom
Black Hills, SD
R
Well if that's the case how are they still putting aluminum hoods and tailgates on them? Or better yet how are they putting any body panels at all on the F-Series or Expedition?
It's a very minor change and done to cut costs by using cheaper material and the fact Ford can now stamp them in-house, but it's still a feature delete that removes value from the vehicle. If Ford can't find enough aluminum for a couple small front fenders they are going to be having major problems producing those all aluminum products soon.
Regarding prop rods. All models had struts before 2022. The 2022 has a re-designed upper radiator support panel to hold the rod.
Since there are many different threads on this I feel it's now worthy of a sticky. Just hit the edit button on this post to add any new additions so it keeps this thread updated.
1. no rear folding headrest
2. no hood struts(as of 2022)
3. no PRNDS light
4. no glovebox damper
5. no RANGER embossed into the Lariat seats
6. no console (pen) cubby
7. no 12V outlet in the console
8. no bright trim rings on the 12v covers that matched the radio knobs
9. only 4 bed tie downs instead of 6 (as of mid 2019??)
10. no engine cover
11. no key slot on tailgate lock
12. no owners manual cover
13. no power folding mirrors on XLT 302A
14. Eco badge on tailgate
15. no plugs in the rocker panels
16. no ignition bezel (has always been missing)
17. steel front fenders (aluminum before) 2022 and possibly some late 2021's
18. no bright button on parking brake
19. no color keyed tailgate handle on Lariat just black plastic without chrome pkg.
20. no aluminum spindles, they're now steel
21. rear passenger doors no longer have external touch lock
22. front seat headrest tilt adjustment
o_O That's growing by the hour...
GearHd6
Connecticut
Ram 2500
I guess I don't get what the big deal is with switching to the steel fenders? You do realize that aluminium corrodes, just in different ways. Once you get a chip, over time it'll start jacking the paint off. There's so much other steel that'll rust that the fenders aren't a big deal. If you're in a corrosive region, look into getting it Fluid Filmed.
