KNOCKOFF Ford Ranger Raptor Grille
Arc Ranger
Palm Harbor, FL
2019 Ranger XL SuperCrew with STX package
Dang, thought I'd be the first to paint mine!
Actually used Lightning Blue for it. Pleased with the result!
That looks great. I'm assuming you got a can of spray paint with the lightning blue? If so, how did you go about getting that?
Mellow
DFW, TX
The painted ones look great... not sure I can get close w/the Platinum White.... where's a good source?
User79
Justin
2019 Ranger XLT
Go to your local automotive paint store & have them mix up a rattle can or 2 that matches your paint code. They are typically around $20 a can (single stage) without hardener....about $30 with the hardener. You can also get separate base coat & clear coat.
TacoHawkRanger
Ray
NW Florida
2019 Ranger XLT FX4 Sport; 2013 Toyota Tacoma TRD Sport
Site Developer, USAF
I got mine here. https://repaintsupply.com/r-e-color-coats-custom-matched-aerosol-spraycan-11-ounce-p3401.html Paint and clearcoat (also ordered from them) went on great. I'm a crappy painter, and it turned out well. The only blemish was because I put on WAY too much clearcoat.
I used black for a primer, so mine seems to be a touch darker than the body paint, but that may just be because of angles... Lightning Blue has quite a range of tones. I think Hot Pepper Red guy bought paints that are close to the Ford colors.
Snowdigger
WI
2019 XLT Ranger
Any specific prep required - sand or primer before painting? Any tricks you learned? My grille should be here this week and considering painting silver ingot.
TacoHawkRanger
Ray
NW Florida
You can sand before primer if you like. I didn't. Definitely put on a primer coat. I use Rust-oleum for almost everything, so that was primer. I did wet sand my primer layer (600 grit). Otherwise, don't be like me and spray too much on. The bottom of my F has a big thick ugly glob of clear coat because I sprayed WAY too much.
Fawnbuster
Indiana
Retired 34 years as LEO
Great look! I've been in contact with that same seller, just haven't pulled the trigger yet. Hoping someone come up with an amber led light kit that is plug and play so it completes the Raptor look
***Install Video Courtesy of @j0shm1lls***
THe Raptor Grille Installed in the above Video is an OEM Raptor Grille. The Knock Off Raptor Grille shown below does NOT require any modification to the grille as shown in the video above.
Get THIS ONE!! $274 shipped! FITS like a Glove on the NA Ranger!!
https://rover.ebay.com/rover/0/0/0?mpre=https://www.ebay.com/ulk/itm/264214175499
Mellow
DFW, TX
Ronbo
Ron
FL, CT, TX
2019 Ford Ranger XLT FX4+
Just got mine yesterday. Need it to stop raining to install.
Man, I hear you on the rain. It's rained here in Ft Lauderdale every day for like the last 2 weeks or so. I just submitted a change order to my dealer for my Ranger to have the optional pontoons added. Blacked out of course.
chasvs
chasvs
Tampa
I'm going for a 12 inch LIFT!
Wschnitz
Will
Bellingham, WA
Dealers buying these in batches off alibaba now and selling for 3x the price lmao
