weasel1
Derek
Pembroke, Ontario
Nuclear Operator
I guess that means I won’t be upgrading since you have the same build and equip group. What is your vehicle build date? Mine is 6/2019.
Mines 9/19
RobmJ
Austin
Just updated to 3.4.43 no problems. Good luck all!!!
Once it restarts, do I pull out the usb? It seems like it automatically starts updating again
Fjoyner
Forrest
Missouri
2019 Lariat 4X4, FX4, Black package
Retired Optometrist
I am not a forscan user as I am not comfortable messing around with vehicle settings. Has Ford really not identified which 2019 Ranger configurations or build dates will lose climate controls upgrading from Sync 3 to Sync 3.4.43? I have a 2019 XLT 4x4 Supercab (equip group 302A) and no Navigation. I really want to upgrade, but I do not have time to deal with Ford chat and/or the dealer if I were to encounter this issue.
Agree completely....there has to be a fixable common denominator, but it would require Ford to acknowledge the problem first, then figure it out. To my knowledge, they have not and are not doing either.
devbloggs
Devbloggs
Canada
2019 Ford Ranger XLT 4x4
also updated today, backup camera and everything seems to work fine EXCEPT climate controls are gone.
tried changing some options in Forscan with no luck, ill try a master reset
UofMEngineer
See this post for a way to determine if you’ll have the problem prior to updating. Beyond that, all I can say is all information on the problem has been reported for investigation / a fix. Unfortunately, that’s about as far as my assistance on that can go. I’d guess there will be some SSM to dealers on it eventually that may have more information.
Fjoyner
Forrest
Missouri
Retired Optometrist
Did you pull out usb after first reset ?
For me, I missed the first pull because it was very brief and then it began the process over again, which, in itself a fail of the update process, but I pulled it after the second one. Honestly, I don't think it would have mattered. I feel safe in saying this is a fail of proper testing before the release of the update to the public. Sadly it happens all the time in the computing world. Poor QC, but happens.
Fjoyner
Forrest
Missouri
Retired Optometrist
That would be it exactly for me. AFAIK, just CC took a dump. Thanks for trying...hoping for the best.
Voltune
Washington State USA
Ranger 2019 XLT 4x4 Supercab (302A)
I tried the linked site in that post - https://www.motorcraftservice.com/asbuilt and get an error. Is that site valid anymore?
Server Error in '/' Application. Could not find file '\\dc18101mc01.prod.f01.dc1.ford.com\q00244\WritableContent\Tabs\motorcraft-service.xml'.
RobmJ
Austin
Same with me. I pulled after the 2nd reset.. you think that’s the issue? I don’t see how that would make the problem
UofMEngineer
It was working earlier today, maybe down at the moment?
Fjoyner
Forrest
Missouri
Retired Optometrist
I doubt that's the reason....just a coincidence, but on them regardless. What reliable software wouldn't say....you've already done this?
TORQUERULES
US
Ranger
I pulled on the first reset. That is not the issue. The update itself is. I love the new interface and I can deal with the camera though I am not sure why that changed, but the climate control is NOT acceptable. Ford needs to get us a fix we can perform without going to the damn dealer.
SandBaja
Larry
San Diego
2019 Silver FX4, 501A pkg, fully optioned,2012 Rubicon, 2017 Cherokee, 2018 Volt
Almost retired
After making the change with Forscan I had to reset APIM for the change to take effect. I only changed the single bit 8 to a 0 at address 7D0-04-01 xxxx xx8x to 7D0-04-01 xxxx xx0x
Forscan is not the friendliest tool IMO. There is a bit of familiarization you need to attain first. Not sure I would recommend it to someone with two left software hands or a computer novice.
This is a perfect case for OTA to address. Ford has the database, knows which vehicles are impacted and could send down the single bit fix without too much of a challenge.
SandBaja
Larry
San Diego
Almost retired
Mine also went to a constant seek and restart after the third boot. I let it run multiple times and finally pulled the USB after ( third boot) recognizing the pattern. I had updated prior with cyanlabs bit don't think that was a factor.
