lazynorse
- Joined
- Mar 16, 2022
- Threads
- 41
- Messages
- 320
- Reaction score
- 597
- Location
- Washington State
- Vehicle(s)
- Ford Ranger Crew Cab XLT FX4
- Occupation
- Public Health
- Thread starter
- #1
Truck: XLT Crew Cab FX4. Stock suspension.
Picked these tires after much research. Went with them because they're rated well in all conditions, specifically wet handling (needed in WA State), weigh less than same size C load BFGoodrich , Coopers, Falkens and other ATs and are cheaper ($288/tire) than some of the most popular ATs. They just might be the tallest tires you can fit on a stock suspension. No rubs and still some clearance from the crash bars.
A couple members here gave them high marks too. I only have 5 driving miles on them so far, but the drive home was fine, didn't notice much difference over the stock Hankook ATMs.
Stock Hankooks were 30.5" while these new Firestone Destination XTs are 32." That is on paper. Once I got home, on the truck they measured just over 31." This must be due to the deformation of the tire carrying the load of the truck. It must be 32" fully inflated off the truck.
Wanted to figure out what PSI adjustments - if any - I might need. Same goes for Speedometer. This is purely theoretical, as its all internet research based, using established calculators against Ford Ranger specs and my exact new and old tire specs.
At some point, I'll either take the plunge to figure out ForSCAN (is this even still an option? thought I read problems on new licenses?) or buy a terribly overpriced device that just does speedometer calibration from tire size. I'd rather my speedometer, odometer and MPG estimator be more accurate. Once I get some paved and unpaved miles under them, I'll report back on these Destination XTs.
Here's the source material, and my MPH increase cheat sheet. Hope this is helpful, let me know if you notice any errors. Love to hear your attempts to adjust to different tire sizes.
Tire Pressure Calculator
https://overlandracksontario.com/tire-pressure-calculator/
Ford Ranger Specs
https://www.thecarconnection.com/specifications/ford_ranger_2022
Firestone Destination XT Specs
https://tirepressure.com/firestone-destination-x-t-tire-pressure
Firestone Destination XT LT255/75/17 C Load Pressures
34 Front, 37 Rear OR 33 Front and Back (using max GVWR divided by 2, more conservative than gross axle weights )
Speedometer Calibration Calculator
https://tiresize.com/speedometer-calibration/
Old MPH = New MPH (265/65/17 to 255/75/17)
40 = 42
60 = 63
70 = 73.5
80 = 84
90 = 94.5
Ford Ranger Specs
40 = 42
60 = 63
70 = 73.5
80 = 84
90 = 94.5
