Interior Roll Cage
Dereku
Derek
Chicagoland Area
2021 Ford Ranger
Project Manager
Can these be bought? Thought they were more of a weld in place thing.
Tom_C
Tom
Virginia, USA
System Admin, Retired
Interior, like inside the cabin? Talk about headache rack.
TopoRanger
TopoRanger
Brad
Missoula, Montana
2020 Ranger XLT FX4
Mechanic
Yeah inside the cab. I don’t need one for the bed. I don’t plan to properly Baja the truck.
baloo2650
Eric
Elmira, Ontario
2021 XLT Tremor
Millwright
I’ve built a couple full cages in race cars. They’re not something you want in a road vehicle, you’ll end up ripping out most of the interior, cutting up the dash, as well as having to climb over the door bars to get in and out. Will be issues with airbags, seatbelts etc. also. Just some things to consider… Cheers
Dereku
Derek
Chicagoland Area
2021 Ford Ranger
Project Manager
Good point there. In the 90s it was possible now, not so much.
RedDakooter05
Illinois
2024 Nissan Frontier S 4x4
Why would you want this inside the cab, especially if you're not going to be racing it or whatever.
Maxacceleration
Max
PNW/NCW
‘20 Ranger XLT
Topo’s Ranger is a pretty trick/custom specific use vehicle.
So I could see a cage stuffed in his cab.
A full race cage would tie into the frame (or tube chassis). A ‘street cage’ may have flat metal plates attached to the floor in 4 or 6 points. A street cage may not need door bars to restrict entry. Four point belting to think of.
It may still reduce cab crush in a rollover…
That said, its tight quarters. Creative tube placement with controls access thought out to keep in mind. Some pull the headliner, some have cut off the roof, built a cage then re attached.
Don't melt plastic or burn interior!
I am weight conscious… a lot of extra weight added is my thought.
Hmmm…
TopoRanger
TopoRanger
Brad
Missoula, Montana
2020 Ranger XLT FX4
Mechanic
I don’t plan to race it. Definitely won’t be doing door bars. Just thinking something similar to the jeeps with the sport additions just a couple more bars, or just a little further than that. I’m wanting to wheel it more. SAS it then 40s. Like totally opposite of Baja racing.
Blmpkn
Maine
2010 ranger
Interior cages are for race vehicles.. or at least something where you wear a helmet while operating the thing. Getting in an accident and wailing your head off of the bar that goes right past said noggin is a good way to end up drooling on yourself for the rest of your life.
Exocage sounds like the way to go in your case to be honest.
Dereku
Derek
Chicagoland Area
2021 Ford Ranger
Project Manager
Exocage it. Those look sweet. Especially if you are going to rock 40s. Give you exterior protection, mounting points for stuff, and the roll over protection you want.
