Inside tailgate panel
Maryland
2019 Ford Ranger Lariat
Are there any good options to replace the inside of the tailgate that aren't ridiculous price? I'm aware of the Mountain Hatch panel but I can't afford $260 for a novelty.
I'd be ok if the option only replaced the access panel for the tailgate Handle. I've just had a times where it would be really nice to have a flat surface to work on.
2021Ranger
Barry
NJ
2021 Ranger
I have weathertech cover. Fit is very nice and it works for me..
Firefighter681
Maryland
That's a decent option. Not a perfectly flat work surface, but has the added benefit of protecting the tailgate... and doesn't cost a ridiculous amount.
RedDakooter05
Illinois
2024 Nissan Frontier S 4x4
Firefighter681
Maryland
What exactly do you intend to do on it?
ABS plastic sheets will be a great option if you don't plan on slamming cinder blocks across it.
Easy to cut, and can be attached via adhesives(glue/3M tape) or screwed on if you're good at measuring...
https://www.acplasticsinc.com/categories/abs-plastic-sheet
Amazon has cheaper options, but most I've seen are 10x10 or 20x20".
https://www.amazon.com/abs-plastic-sheet/s?k=abs+plastic+sheet
That's not a bad thought!
Danager
Dan
Alberta
2019 Edge
Manager
HDPE sheets are available. Here is a quick example from Home Depot.
Honestly it will depend on how much you are willing to spend. I myself went with the Hurricane Fabrication tailgate storage. Reason for.me was the lack of storage under the rear seat(still can't figure out why Ford did that). In general it was nice but also made the tailgate a bit heavier. If you simply plan to leave the tailgate as it is even with a different plate o wouldn't even bother.
OFC Ranger
Jack
ZR2
Here
XLT
This is a great way to go.
If you’re handy, have the proper tools, some skills, a good work space, and a ton of patience, you could fabricate something really nice.
Living The Dream
