Towing Package: It's more than just a hitch and some wires.
HenryMac
Mech. Engineer - Retired
Something I just noticed today and thought I would share. The rear bumper center section is different when your truck has the factory tow package.
It's modified to move the hitch receiver up higher, thus giving the truck a better rear approach angle.
Well done Ford. I'm surprised they don't make of note of this on shop.ford.com?
"The Trailer Tow Package increases the Ranger towing rating and includes hitch receiver and 4/7-pin connector."
Good detailed info John! I noticed that I did not scrape my hitch when we were up in Sedona off roading. When we were on the exact same trails with my Tacoma (with the off road package) I couldn't even get over the first hump without severely scraping my hitch.
On a side note is there a larger transmission and radiator cooler on the Ranger tow package? I know with the Tacoma it does.
VAMike
2019 Ranger Lariat SuperCab
No, the functional parts are just the receiver and fancier connector. Wiring is the same in all models, as are transmission and radiator. The 10 speed is always connected to the coolant.
HenryMac
HenryMac
Here's a pdf, showing what it takes to install a Ford factory hitch and related components......courtesy of member earsmccoy on this thread ----> Trucks w/o Tow Package?
HenryMac
HenryMac
very cool. just FYI, "rear approach" is typically called "departure angle"
Thanks.. Keeping it simple, back on the farm we would have called the low mounted hitch "The Ruptured Duck" look. :turkey:
rang19ca
Chuck
Carpinteria Ca
Retired Diesel Mechanic
I installed the factory tow package on my Ranger. It is really a complete different bumper assembly that reuses the visible painted or chrome pieces and the top plastic skin. It also comes with an additional bolt on each side. It fits up against the frame very well.
Hounddog409
Tod
Ohio
F150
/QUOTE]
I also have a little button for towing on my console......
HenryMac
HenryMac
All Rangers have that....
Without the tow package the bumper itself can be used once a ball is installed. And the bumper has a significant structural support when the tow package isn't provided.
Is it as good as a hitch? Nope.
Is it better than a sheet metal bumper? Yes, a lot better.
Here's some photo's I took of an XLT..
scubalizard
Houston
2019 Ford Ranger XLT
think also the change is to be able to see the full hitch in your backup camera. while you may be able to see the hitch in an aftermarket setup you would really know where your truck ends in the camera.
BRanger
Beau
Baton Rouge
2021 301a XLT Cactus Grey
In all of Ford's marketing material, they state that the Ranger can tow 7,500 lbs *when equipped with the towing package*.
My question is, if the truck doesn't come with the towing package and you add an aftermarket hitch, what is the tow rating? If there isn't an upgraded radiator and axle ratio like on the Expedition and other models, is it just up to the rating of the hitch that you install?
