The OEM pan does not have a drain plug. That is why many of us have or are changing the OEM plastic pan for an aluminum one with a drain plug. We are also installing a extended dip stick available from a member here, to more easily check the level, which needs to be done hot. My plan is to do a drain and fill every 30K and a filter change every 60K.can I ask a dumb question? is there a drain plug on the transmission pan or do you have to drop the pan for an oil change? if the pan has to be removed then why not change the filter and refill with oil?
