Head rest
mtsoxfan
NEK VT
I am having issues with my neck, and driving is even worse as the headrest tilts my head down a bit. I have thought about heating and bending the bracket/bars at the point the come out of the headrest, so the up/down function would still work, if I could take them out of the fabric. I also assume that the bars are hardened steel because they are a safety devise. So, as I write, I'm actually having to rule that out.
Any ideas?
Maybe reclining back more would change the angle enough to help.
JaysOnTheEDGE
Jay
Office Equipment Technician
i though it was adjustable if you grab the top of the head rest and pull forward it should tilt forward thought it had a few clicks then if you pulled it all the way forward and released it snapped back to upright position
mtsoxfan
NEK VT
Yes, but the angle still forces head forward
AdamHarris
Adam
Blue Oval City, TN
Collision Repair Instructor
Maybe I have curvature of the spine or something but not matter where I adjust my headrest I have to lean my head back to contact the head rest. So your problem seems hard to understand for me.
CO2Ranger
Your best bet is to put padding on the seat back itself to force your spine forward away from the headrest. I have the same issue, especially when driving off-road for extended periods of time.
I had a friend who had similar issues with his neck and seating position and he found by using one of the neck pillows you use on an airplane helped him a lot. Might be something to try?
DHH
Here...but sometimes there
2019 Ranger Lariat FX4
I don't think my head even touches the head rest.
Just how big is your head?
Are you Jack from Jack In The Box? :wink:
Tracy Bowman
Tracy
I know exactly what he’s talking about because it does me that way also. I like to sit straight up, but if I do, the headrest does seem to put my head forward a little. But , if I set the back down a little bit that helps my neck situation. I have found my happy medium.:)
Fawnbuster
Indiana
Retired 34 years as LEO
Thanks, I tried, but that only affects back angle, not neck angle.
In the past I was able to remove a headrest and flip it around and reinsert it facing the opposite direction but that was in one of my Dodge Sheriff's vehicles, not sure if it can be done in ours. Wonder if a rear seat (if you have a crew cab) would fit in the front seat holes?
FloggingBishop
Tyler W
Canada
2020 Ford Ranger Lariat FX4
Operator
I’m the opposite, I have mine tilted all the
never had a problem with my headrest, but i am a slouch.
kinda gorilla like posture and maybe a Sasquatch lurch when i walk.
maybe I need to do some yoga and some stretches??
just install a damper, that’ll soften you up
the5Gmartian
Jesse
Washington, D.C.
U.S. Navy
It’s a ratcheting style headrest, so you can adjust it however you like, just pull on the top of it as someone above mentioned. Sounds like you need to work on your posture too. I know i’ll get neck and lower back pains if I sit wrong
