GFB DV+ install (pain)
My12SecRanger
Patrick
Las Vegas
21 XLT Ranger 2wd
Ford Tech
I installed the DV+ today and just wanted to vent, had to drill out the charge pipe holes for the bov to 15/64 drill bit as my stock bolts were some kind of weird self-tapper style, nevertheless I got errr done with some 6mm by 45 long bolts with lock nuts just in case anyone runs into this issue. also had to grind off the lower section of the front bolt as there was no room for a lock nut to fit barnacles.
I ran into the same thing with mine. The instructions also say to clock the thing one way but the mounting ears on the thing will only let you mount it one way. They’re not symmetrical spacing on the ears. I reused the factory BOV self threaded screws to mount it. The provided hardware was a no go just as you said. Still on there solid with the factory fasteners though.
Just a reminder, once a year pop it off and lube it up!
My12SecRanger
My12SecRanger
Patrick
Las Vegas
21 XLT Ranger 2wd
Ford Tech
that is weird my stock bolts are not long enough to go thru the spacer
taildraggerpilot
Carl
Kennesaw, GA
2020 Ranger Lariat FX4, 2022 MINI JCW Hardtop, 1967 Mooney M20E
Boeing Guppy Driver
Yes, in most cases the included hardware doesn’t do a decent job. I have an upgraded all-metal charge pipe system in place, so longer machine cap screws were the answer.
My12SecRanger
My12SecRanger
Patrick
Las Vegas
21 XLT Ranger 2wd
Ford Tech
charge pipes are next on the list
Mr.Scary
Ontario
2019 Ranger sport 4x4
Heavy equipment operator
Or just buy a turbo smart. Lol. Fits lick a glove
My12SecRanger
My12SecRanger
Patrick
Las Vegas
21 XLT Ranger 2wd
Ford Tech
had the turbo smart on my last ford sold it like a dummy
DROZ23
Dan
VIRGINIA
2022 Ranger Tremor
Beening Badass
They are sized out for a reason. I just put a little more tension on the last 1/4 inch and they drove in fine. They sealed like a champ.
