FX4 Off Road Angles Display
Stefano187
Stefano
Italia
Ford Ranger 2.2 limited 4x4 EU
DRIVER
Good morning, my name is Stefano and I write from Italy (I apologize if I will not be very clear but I use a translator), I own a Ford Ranger of 2019 limited version (European T7) I would like to enable the off-road menu with FORScan but those who did tell me that the inclinometer section only the part of the steering and differential goes. I ask you how I can solve it and if there is a missing sensor or control unit and in case you can find it to add it. Thank you so much for your availability, I'm going to take a picture of what you've shown that you've done it to.
t4thfavor
Chance
That menu should work fine, it's the Intelligent 4WD menu that doesn't work properly.
the Wiki post here (https://www.ranger5g.com/forum/threads/forscan-crowdsourced-wiki.2008/) shows this.
Off Road GaugeEnables Off-road gauges (enable in conjunction with Off-road Screen)IPCGizmokid2005
Off-road ScreenEnables off-road gauges (enable in conjunction with Off Road Gauge)IPC720-07-02 (x3xx xxxx xxxx)Gizmokid2005 / WhiteLightning19 (AS-BUILT)
Recent versions of Forscan should have this in the "menu" configuration so you don't have to use the As-Built section.
Stefano187
Stefano
Italia
DRIVER
So there don't have to be any other control units or sensors, is it just a code problem? Thanks again for the help because I have a lot of add-on work to do but here in Italy Ford does not understand anything and especially for the European version many things are not there (central grid for central speaker speaker) however I try and update you
t4thfavor
Chance
No extra sensors needed on the US version. You will soon see if yours has the sensors. I expect it does.
Stefano187
Stefano
Italia
DRIVER
All right, in case it doesn't work, what might be the reason? Where does the tilt signal come from?
t4thfavor
Chance
There's an accelerometer in there somewhere, I can't remember what module it's in, but it could be in the collision avoidance stuff. Turn it on first and see what happens.
t4thfavor
Chance
I might get Forscan just so I can enable this on my non-fx4 4x4 w/locker...
If you can find/buy the Terrain Management buttons, you'll have like 2/3 of the FX4 package for about 100$ in total :)
Stefano187
Stefano
Italia
DRIVER
Ok perfect, in the anti-collision I guess not because those who enabled it have it and do the above thing, I try and update you, instead of meaning that if you find the menager keys you can enable, which is just a matter of setting? Because the raptor for example handles it from the computer not from the keyboard on the 4x4
Stefano187
Stefano
Italia
DRIVER
Another thing, FORScan, where do I unload the latest version?
