Fox 2.0 coil over adjustment
Steve23
Stephen
Maryland
2020 Ford Ranger Lariat
Software Engineer
Apparently I can’t edit titles. Guess that’s what I get for doing this on my phone. Coilover not cool over I guess a mod edited the title. Thanks!
Edit: Used a heavier duty spring compressor to relieve the pressure and hand turned the adjustment collar. Very easy with the right compressor.
Hey all,
So I bought the non-Ford fox 2.0 kit. Rep from fox confirmed that it’s preloaded to 2.5” and to get the 3” I want I need to adjust the collar 1/4”. Sounds easy but I can’t seem to actually get the collar lose. I’ve seen some videos for other trucks but the coil overs look different. I’ve tried with a spring compressor but can’t seem to compress the bottom spring that is actually pushing up against the collar.
Does anyone have some ranger specific videos for it? Or have done it yourself?
Thanks
Sheepdog
2021 Ranger SuperCrew 4x2 XL
Retired police officer
You don't need a spring compressor to adjust spring preload on any quality threaded coilover.
What does the Fox owner's manual say that came with them? Is there a set screw? A pinch bolt? A lock ring? Are you using the correct spanner?
Steve23
Steve23
Stephen
Maryland
Software Engineer
@Sheepdog
So these don’t use a spanner wrench. There’s a single Allen head pinch bolt keeping the collar closed. Loosing that bolt doesn’t make it any easier. Also the manual says to lift the truck and use a spanner but I’ve seen mixed reports of being able to adjust these while on the vehicle since it doesn’t actually use spanner wrench.
if you zoom in on the collar on the bottom you’ll see there’s no spanner holes
Sheepdog
K.
Does this help?
That's ridiculous...
Steve23
Steve23
Stephen
Maryland
Software Engineer
K.
Does this help?
Nope that’s the first result in google lol. Watched it a few times and it’s different
Sheepdog
Well, I'm glad you found the pinch bolt on the collars.
The Fox 2.0 is a popular entry-level RHA coilover- I'm sure somebody here should be able to help you out...
Steve23
Steve23
Stephen
Maryland
Software Engineer
Also doesn’t help that the manual seems to also be for other coil overs that can use a spanner wrench
Steve23
Steve23
Stephen
Maryland
Software Engineer
yeah and if anything I’ll take another look once it’s installed. Thanks for trying to help!
Sheepdog
I wish you the best on that...
MTB-BRUH
Tyler
Shingletown CA
2019 Ranger Base
Shop Manager
I literally just bought some wheels from a guy and he said he put them in a press and was able to loosen them by hand or tighten them
KevinG
kevin
nevada
2020 Ranger XLT
Business owner
Yup! very easy to do also.
krisrayner
Kris
‘20 Ranger FX2
Steve23
Steve23
Stephen
Maryland
Software Engineer
Well looks like I gotta find someone with a press. I was wondering if that truly was the way to go since the F150 video above that I found the guy was using a press.
Thanks for the tips all. Its a shame that the fox manual says you can do it on the truck and use a spanner wrench when everyone else says nope and there's no spanner wrench holes lol
Markubis
Nashua, NH
Mechanical Engineer
Can't you just use some spring compressors and manually compress them while they are still installed?
Steve23
Steve23
Stephen
Maryland
Software Engineer
That's what the manual says but it also says to use a spanner wrench which these coilovers don't use.
