FORScan Modifications
12Bravo20
Missouri
2020 Ford Ranger XLT FX4
Plus I never said how useful or not the power distribution screen actually is on the Ranger. All I said was that I have the screen and it functions as it should.
lukdeg
Luc
Edmundston
Ford Ranger lariat 2023 Cactus grey
paramedic
I am dumb, I can intubate people, I can give meds to revive you, can shock you and I can even deliver a baby in the back of a small box..... but for the love of god, I have no freaking clue where to go to activate bambi mode in forscan -_- I am new to this, I just want my fog lights to be on when on high beam and don<t want to mess up the truck...!!! HELP!!! here's the screen I have and I dont know where to go after...
bonus: if anyone is in the Madawaska Maine or Edmundston region, Iwould love some help!!
21Blackout
Brian
Ny
21 Ranger
Warranty Administrator for FMC
its in the bcm
Fog lights if High Beam is on (AKA - Bambi Mode)Allows the fog lamps to stay on when the high-beams are used.
lukdeg
Luc
Edmundston
paramedic
its in the bcm
Found it and now I can't stop looking at those available options I could change ??
Bambi mode activated, drl turns off when signal light is on ?
edit: changed the color of mabiance led when opening the doors to white, changed the splash screen to bronco, activated the speed limit sign (yup, got the NA version!) also added the heated seat icons on main screen (not available in the climate screen?)
twk
Minnesota
'17 Mustang GT drop top, '22 Ranger Lariat Fx4 SCABbie.
Flight Simulator Engineer, retired, unemployed, burden on society.
The Ranger does not have a center differential. It has a transfer case which is a big-ass chain connecting two sprockets together. It is literally incapable of sending more power to one or the other.
Kind of an old thread, but I have to step in here.
The above is correct. It says in the manual...
  1. On vehicles with an electronic shift-on-the-fly transfer case, the transfer case distributes torque to the front wheels by mechanically interlocking the front and rear driveshafts together.
The front and rear drive shafts turn together. They are locked together. They turn at exactly the same RPM. It's a Transfer Case. It is not a differential. There is a huge difference.
RAYJAY
UNION DALE PA
IRC that PID gets its feedback from the wheel speed sensors, could be a traction control making it not do 50/50
can you go back to the stock settings ? is it an aftermarket tail light or stock ?
LB'sTremor
Loren
Tampa
22 Iconic Lariat Tremor
IT
In Forscan it automatically DL the as builts you can restore to stock and start over
LB'sTremor
Loren
Tampa
IT
look at the bottom as built tabs in Forscan and watch the video I just noticed you are in the UK not sure if it will work for you
LB
What specifically did you change?
Hex Line or Easy Line .
Craigo20162
Craig
York United Kingdom
Ranger bi turbo 69 plate
Stone
Not a clue tail light bright but when brake can’t see light. But when tail light off you can see brake light
