FORScan Modifications
RCMUSTANG
Ray
Los Angeles
2017 Fusion 1995 Ranger
Mine has it stock.
WLFPIR8
Ethan
Central Ohio
whor.us
2019 Ranger Lariat FX4/Sport in Saber Orange
Systems engineer by day, maker and multimedia guru by night.
I know we have a way to remove the FM/AM radio icons and such from the audio screen. Has anyone heard of a way to remove the XM radio stuff? I don't use it, and whenever it gets selected it has a popup demanding I buy it. Just rather remove any trace of it.
ScubaSteve
Astoria, NY
2019 Ford Ranger STX, 2019 Jeep Wrangler JLU
Curious if anybody has ever seen the Ford Surveillance Mode option in ForScan or if somebody can figure out how to make it work. All of the necessary hardware is there and I know there are other police interceptor options that have been discovered in ForScan.
For those unfamiliar...
Hambone437
ā€˜19 Ranger Lariat 4x4 Magnetic Gray / 2020 Explorer Limited RWD Magnetic Gray
I would be interested as well. I was pocking around ForScan last week for something unrelated and I donā€™t remember seeing anything about ā€œsurveillanceā€ that stood out. So if itā€™s there it is probably called something less specific. I would have been ā€œtriggeredā€ by the term ā€œsurveillanceā€. :bandit:
ScubaSteve
Astoria, NY
Haha. So after some further research I found out that this was a separate module manufactured by a company called Intermotive for Ford. For what it's worth they make products that work with a variety of different makes/models, but nothing for the current Ranger. They do have some cool stuff though.
quirkybar8
Indy
2019 Ford Ranger 2WD XLT
FYI the OBDlink EX is $10 cheaper direct from scantool.net right now. Quite an Amazon tax otherwise.
Jerry Caldwell
Jerry
Granbury, TX
Ranger Lariat
Retired Architect
Itā€™s odd the Lariat doesnā€™t have the seat heater buttons on the SYNC screen right from Ford. Pretty cool I was able to add them using FORSCAN. Sure it is redundant since the buttons are just below the screen but I dig it.
I bought a Lariat FX4 in June of 19 and it has them.
apotocki
Alan
Rochester Hills, Michigan
2019 Ranger XLT
Network Force Analyst
Please bear with me. Iā€™m looking to get into ForScan and make a few changes. Done a lot of reading through the 2 threads and know the unit Iā€™m getting. What Iā€™m trying to confirm is if a couple of the changes I want are possible and confirmed.
1) change the auto turn signal from 3 flashes to 4 or 5
2) change the DRL to parking lights ONLY. I do not want my low beams on - I have an XLT
The others I found and know they work - Bambi mode, Welcome screen, beeps...:
Any information is appreciated. Thanks in advance.
WLFPIR8
Ethan
Central Ohio
whor.us
1 = No, no one has found this to work yet. I've also been wanting to change it. The F-150 version of the Forscan mod doesn't work either, FYI.
2 = Yes, that is built into the new forscan software and is one of the "menu" options, so, you don't have to manually change codes for it. The setting is in the BCM (Body Control Module) I think.
apotocki
Alan
2019 Ranger XLT
Thank you. Much appreciated. I feel a bit better about ordering it now as the DRL item was a priority for me.
