Fitting 285/75/17
cembley
Cuilean
Utah
2021 Ford Ranger XLT, 2023 Toyota Tundra Limited
Sales Rep
Hey all,
Looking for some help/advice before ordering tires. My current setup is a 21' XLT Sport with Fox 2.0 coils. I'm hoping to fit 285/75/17 AT tires on stock wheels and haven't been able to (clearly) understand what it will take. As far as I've read, I need high intrusion crash bars and to cut the egg crates. Am I missing anything? Thank you in advance!
Stic-o
Lake View Terrace, CA
Yes, your just removing the egg crates. You will still get a bit of rubbing in and out driveways.
cembley
cembley
Cuilean
Utah
Sales Rep
Thank you! Were you able to fit the spare back under the bed?
Colo_Ranger
2021 Ford Ranger XLT FX4
I run the same size; here is what I did: I removed the front and rear crash bars, removed the waffle boxes behind the fender liner, secured the fender liner to one of the bolt holes used for the waffle boxes. I run 1" wheel spacers on OE wheels. I have also cut back the crash bar mounts (and I need to cut more as I kiss them on full turns).
Yama_Ranger
Earth
2013 Raptor Soon 2021 APG Ranger
The spare will fit. I have a 35x12.50r17 in the stock spare location. Be sure to add an additional safety strap as the stock spare tire winch cannot handle the weight of an oversized tire. Otherwise, you’re good to go.
cembley
cembley
Cuilean
Utah
Sales Rep
That's super helpful! Looking forward to doing some cutting this weekend.
THANK YOU! With my luck I most definitely would have been having fun on the highway trying to retrieve that spare had you not said that.
Fx4ranger2019Larait
Ricky
SoCal
2019 Ranger FX4 Larait
Sprinkler Fitter
I run 285/70/17 range E 80lbs + with wheel and tire never had a problem with spare but might add a strap now. Thanks couldn’t hurt for additional safety
Zepproxx
Brian
Nashville
2021 Ford Ranger XLT Sport 4x4
Remodeling Contractor
Is it the 75 that will rub?
Stic-o
Currently not rubbing at all. 285/75/17 Toyo R/T Trails.
Also same size spare is now under the bed of the truck.
