Fan Shredded Radiator
tygr2007
Tyler
Naples, FL
www.tradewindnaples.com
Designer @ Tradewind Designs
So, I haven’t seen anybody make this post. I did a search on all the forms and I couldn’t find anyone with this problem. Just today I was offroading my truck, just some light offroading. Seriously, nothing major.
All of a sudden, my coolant temps go through the roof. I immediately shut off the truck and goes to the front and open the hood. That’s when I noticed fluid, coolant leaking all out from the bottom of the engine bay. After a little bit of discovery, we found that there was a bunch of holes around a dent. Now, we believe this dent came from the fan hitting it.
Unfortunately, I’m really not sure how the fan even made contact. Maybe the engine mounts are bad, but with the vehicle only having 22,000 miles you wouldn’t think that would be possible.
so, like I said she’s sitting at Ford right now waiting to be looked at. Hopefully it’s covered under warranty, but I’m kind of nervous about the offloading thing. It got towed out when it was all still muddy so they’re probably gonna try to pull something on me. Yes I’m modified, yes I’m lifted. But honestly, this should have nothing to do with the engine. I have zero engine modifications, only a tune. Which I made a point to take it off before they towed it away.
Hoping all goes well, if anybody ever had this problem, please let me know.
That sucks Tyler,
Is it possible the hose holding the fan clutch wire harness failed and the harness got shredded and whipped around, causing a fan blade to deflect into the radiator?
It’s a thing. ☹
That sucks Tyler,
It’s a thing. ☹
Very likely...too bad no other pics...
tygr2007
tygr2007
Tyler
Naples, FL
That sucks Tyler,
It’s a thing. ☹
The fan is perfectly intact. And everything around is fine.
The fan would likely look fine in this scenario - the harness is between the fan and motor and if it’s now missing or wrapped tightly around the fan’s shaft, nothing would look out of place.
It’s worth mentioning to the service advisor as something to look for.
Whatever it turns out to be, I hope it’s an easy fix.
Why is your fan blade black. Every OEM blade that I’ve seen is a light colored plastic. Is it an aftermarket blade?
Good observation Steve. Maybe he had some leftover headliner dye.
Just kidding Tyler - I know you bought your 2023 Tremor in 2023 - was it new?
Stevedbvik1
2022 Ranger Tremor XLT
Yeah the more I look at it the more questions I have. Side by side pictures ?
NerkyMohawk
Nick
2023 Ford Ranger Tremor Lariat
F&B Manager
Never diassapointed by his posts
