Mokume
- First Name
- Jeff
- Joined
- Aug 18, 2019
- Threads
- 44
- Messages
- 1,753
- Reaction score
- 2,740
- Location
- Honolulu, Hawaii
- Vehicle(s)
- 2000 Ranger Supercab (sold 12/19) , 2002 Honda CR-V
- Occupation
- Retired Firefighter III, Honolulu Fire Department
Excellent post Lightning!I decided I wanted LED’s and since I couldn’t find any info online I thought I’d share my findings.
License Plate Lights: 194 (Also Fit: 158/168/12961) Access through underside of bumper, easy access, turn counter clockwise to remove.
Third Brake / Cargo Bed Lights: 912 (Also Fit: 904/906/921/917) There are 3 and they're all the same. No need for a Red bulb due to the red reflector housing. Held in place with 4 T20 Hex Screws. Turn bulb socket counter clockwise to remove.
Turn Signal/ Parking Lights: 7444A (Also Fit: 7443A) A is for Amber. You could use other styles/colors but I would not recommend. Passenger is extremely easy to access, driver is a bit of a squeeze. Turn counter clockwise to remove.
Keep in mind that these LED are directional. They need to be installed in the correct orientation. If incorrectly installed they will not illuminate, so if you decide to change them I advise you to test before reinstalling. I am not sure if this characteristic is common with all LED's but it definitely is with these Philips bulbs.
Another note; I'm not sure how I feel about the LED parking/turn bulbs. They don't appear to be as bright once installed and since there is a resistance difference in them vs the stock bulbs; the dash turn indicator blinks twice as fast, although the blinkers themselves appear to blink normally. I may just toss them, we'll see how annoying it gets sitting at stoplights. Maybe I'll install a resistor. I'll keep you guys updated.
Bulbs used for Third Brake/Cargo Bed Light
Bulbs used for License Plate Lights
Bulbs used for Turn Signal/Parking Lights
Back view of Third Brake Light
Stock Turn Signal/Parking Light
LED Turn Signal/Parking Light
License Plate Bulb as seen from underneath
However I was a non-beleiver in not using colored LED's for the lamps function until I watched a you tube video.
Using a 5K white in a red lens causes the light to look almost orange, while using a red hued LED maintains the original red, only brighter.
