Engine Misfire
Motorpsychology
Prescott, WI
Vagabond
According to the sheet they gave me, they only changed the wire going to cylinder 1. It ran great for the first half of that particular tank of gas. I don't have the sheet in front of me to tell you which error code they got, I will try to update when I have that in front of me again. I will tell them about the plugs when I drop it off again tomorrow.
I hope it's not the same misfire problem 1.5L &1.6L EcoBoost Escapes are having: coolant leaking into the cylinders, usually #2 or #3. There are an awful lot of people with this problem on escape.org
It's the main reason I'm on this forum; to see how Ranger owners are faring as I plan to trade in my 2018 Escape for a Ranger. So far, nothing I've seen to turn me away.
Unless...
t4thfavor
Chance
Unless...
So is this a head gasket issue (on the escape) or is there a crack somewhere? Generally on the 2.0L misfires were usually spark plugs or something terrible like a cracked piston or blown off ringlands.
Motorpsychology
Prescott, WI
Vagabond
It seems to be the block in most cases, around the top flange between #2 & #3. Porous or miscasting is the speculation. Ford is being tight lipped, but overall pretty good with replacing short or long blocks under warranty. Some are reporting out of warranty costs at $6-8,000. I'm guessing it was a bad run of blocks, there are much fewer posts on this now compared to starting around 16-18 months ago. My 2018 Escape has the OEM 1.5L EcoBoost I4 that was built in China at Ford's partner Changan, so somewhere around August 2018 (my build date on the door sticker), some or all 1.5's were sourced from there- at least one was for sure!
ALranger
ALranger
Eric
2019 Ranger XLT
MRI tech
Another update. After a few more weeks in the service dept, they said it was fixed and ready to go. This time they told me all they had to do was install an update on the truck, a couple of the techs drove it afterwards and no misfire. They really didn't tell me anymore details than that. I had my doubts but went to pick up my truck. He asked me to give it a quick test drive before I actually took it. The first mile was great, then it started misfiring again. This week marks the 7th week I've been without my Ranger. I only had it for 8 weeks before it went in for service. I will be calling Ford tomorrow to start a case on it as recommended by the salesman that sold me the truck. At this point, I don't want this particular truck anymore. I doubt they will want to buy it back, but I just don't trust it anymore not to leave us stranded again, possibly farther from home than the first time.
r1ch999999
Rich
Nashua, NH
Software Engineer
They bought back my focus, no questions asked. All I did was insist on a same day check, which they charged me about $5 for.
I start having that problem today, same misfire when i accelerate to pass any car ... i will take it to the dealership by Monday...
Let’s see whats happens
Not to go off topic,but there is another thread on stumbling on hard acceleration. It seems what they found is condensation in the intercooler. On hard acceleration the moisture gets pulled into the intake and causes misfire. Seems like it came from the F150 forum. Fix has been to drill a small (1/16) hole at the exit side of the intercooler to let the moisture drain out. May not be the problem but symptoms sound similar. The OP does live in a humid area.
Gixxers
Joshua
2020 ranger
Steelworkers
Did they find a solution?
ALranger
ALranger
Eric
2019 Ranger XLT
MRI tech
I’ve been meaning to update this for months. All it ended up being was a loose connection. It’s been a while, so I don’t exactly remember what they said was loose though. My biggest complaint was how long it took the dealership to even look at my truck, they had it for a total of almost 2 months. I’ve put 15,000 miles on the truck since the fix with no problems.
If it would help anyone out, I could try to dig up the papers they gave me that said exactly where the problem was.
Sauve30
Washington
I was driving my truck into work today on the highway and I accelerated hard to pass a dump truck and immediately got a shuttering sensation and the check engine light was flashing. I took it to the dealership immediately and they said the cylinder one misfire. I hope it’s as simple as a loose connection or software update. Could not imagine being without my truck for months.
PascoPatio
Lakeland, FL
2019 Lariat
Mine has been at the dealer for 2 weeks now.
Misfire #1, overheating code. Went into limp mode pulled off, turned it off and started right back up. Temp gauge was normal. drove it home and no issue. Couple days later same thing on hard acceleration with a good amount of smoke on start up.
Mind you I am at 72k took it into the dealer and they are saying bad turbo, hope to get it back Monday.
JrRanger
Raul
Orlando Fl
2019 Ford Ranger XLT
Chef
I agree, and it could help out Raul now. Happy to hear they found your problem Eric.
Yesterday i went to get my truck, they just reset the computer and the technician say that he drive it for couple of miles and everything good i asked them if he pressed the gas pedal to rush the truck and they didn’t, so as soon i took the truck from the dealership exit and i pressed the failure started happening again so i left it again so they can check again...
wanted33
Down south in Dixie
Mustang GT, Jeep Wrangler
Old used up LEO
Sorry to hear this Raul. It seems as if Techs don't even try anymore. They just do something, and say it's fixed.
