dtech
If there is no power to heat the O2 sensor I don't believe it can produce accurate info to regulate the AF mix - which could possibly be the source of the misfire code - one might assume that the ecu would log misfires on all cylinders but that isn't necessarily always the case. The wide band O2 sensors are a lot more complex than the old 2 or 3 wire narrow band sensors - which could function without the heating element after the engine was warmed up.Agree with this, but I would get the misfire issue corrected before moving forward with O2 sensor those usually do not fail.
