Slight misfire under partial throttle.
Rich1968
Rich
Pekin, Illinois
Shipping clerk
Has anyone experienced a slight misfire under partial throttle at around 30-40 mph? I had the Ford dealer look at my truck and of course they can't find anything wrong and no codes. 2019 Ranger Lariat. 2.3 ecoboost. Thanks.
My12SecRanger
Patrick
Las Vegas
21 XLT Ranger 2wd
Ford Tech
if you have a decent scanner, you can watch misfire data live and see which cylinder is having the issue, I had something similar on my truck and turned out to be a bad coil pack with no codes
Rich1968
Rich1968
Rich
Pekin, Illinois
Shipping clerk
Thank you everyone for your replies
Rich1968
Rich1968
Rich
Pekin, Illinois
Shipping clerk
Can you order this on Amazon or is it a dealer part? The Ford dealership couldn't find anything wrong of course.
Might be normal operation of the 2.3 EcoBoost. Remember that it is a 4 cylinder. While in drive touch the plus or minus on the shifter and you can see what gear it's in. If you have to manually lockout a gear so it makes it easier
Rp930
Denver
I had the same. Very slight. New spark plugs cured it. The part number changed since 2019. I had about 25k miles
Rich1968
Rich1968
Rich
Pekin, Illinois
Shipping clerk
Thank you for your reply. I appreciate it.
Rich1968
Rich1968
Rich
Pekin, Illinois
Shipping clerk
Charlie's Ranger
Charles
CHARLESTOWN
2020 ford ranger
engineer
I just cured mine with new spark plugs too. No water in the wells. 2020 with 45k misfiring on low RPM loads not bad enough to trigger a code but enough to easily notice the shake. The old plugs look good. I have used the cheap gas since I bought it new. I do still notice a slight bounce when it shifts so i am going to put the DPFE in to see if that improves shifts.
