Engine clicking sound
Don Sethman
Don
piscataway nj
2019 ford ranger lariat
any one experience noticeable clicking sound from rear of engine with the hood up. Sounds like fuel pump or device located center rear of engine by firewall. fuel pump noise?
acsnowrider
JOHN
FL
2019 RANGER XLT
RETIRED FORD ELECTRONIC/DRIVEABILITY TECH
Something new?? New to the truck?? Mine came without the "top engine shroud", and I added it, because it reduced the upper engine noise significantly!! (injectors/fuel pump)
Stop by your dealership, let them listen!!?
FX4Offroad
South Florida
2019 Lariat FX4
its the no4 bearing journal ceramic bearing thats likely starting to fail from running too low octane fuel with a high viscosity oil. It all started when the dealership filled the washer fluid with orange coolant and under pressured your tires because the tailgate damper was overloaded from the 3" lift in the front to give the truck that aggressive tacoma stance. Had the dealership only applied moderate braking force while adjusting your stop start function, none of this would ever have happened.
Wow! That explains it perfectly!
acsnowrider
JOHN
FL
2019 RANGER XLT
Ya, the cold did the same thing to me!!!:crackup: That's why I moved to Az ten years ago!:sun:
Fhatmatt
Matthew
2019 ford ranger
Maintenance
Try chrome polished muffler bearings. And always gap your oil. I’ve got dual dipsticks just to make sure. But all joking aside. The sound you’re probably hearing is the high pressure fuel regulator at the back of your engine bay
Toytec
Central NC
You ain't riiiight..............he ain't wrong either
Toytec
Central NC
Come by my work bay and listen to the high pressure fuel pumps on these newer Toyota's, slash Mazda, slash Subaru, slash BMW or whoever they're in bed with these days.
I'll take the sound of my 2.3 (uncovered) high pressure FORD fuel pump anyday!!
So Ford has a bulletin about this and it is simply the High pressure fuel pump. Its an unfortunate design for noise but it is what it is. Doesnt matter if I use 87 or 91 here in Colorado as it will still make the noise.
