Eibach Pro Truck Stage 1 and Icon Multi-Rate Leaf. Preliminary Review
lazynorse
Washington State
Ford Ranger Crew Cab XLT FX4
Public Health
2022 Crew Cab FX4 XLT. The Eibach Stage 1 kit starts at 3” front lift and accommodates 1” rear lift, which I achieved with Icon leafs set at Option 2 (inch of lift with ~350 pounds). Purchased and installed by Khaotic 4x4 in Tacoma WA. Great customer experience.
No UCAs required, per email from Eibach for this 3” front lift, confirmed by Khaotic during install and alignment.
Prior upgrades were Firestone Destination XT C Load 255/75/17, a 32” tire. These tires are slightly lighter than competitors. I wanted increased size, toughness and tread with minimal hit to MPGs and handling. Pleased so far.
Tire and stock FX4 tested rigorously in eastern WA and OR deserts, high clearance, 4 hi and low trails.
I wanted a true suspension lift for clearance, approach, breakover, etc. I chose Eibach over Bilstein for a reported softer ride on and off road. After hours of research, the Eibach and Icon combo seemed great for cost and performance without going crazy high or low on budget.
More than pleased so far. Road manners are compliant and composed over smooth and bumpy surfaces. Cornering improved, as did breaking. No shimmies, vibrations or any worrisome behaviors.
Ride is more sophisticated than FX4, not harsh in the least. I was worried about increased stiffness, but there is none, only immediate rebound and recovery with much reduced drama. Haven’t taken offroad yet, but hit the parking lot bumps intentionally hard and fast, and highway ‘whoops’ I’m familiar with that nearly launch you.
I was not as put off by the FX4 handling as others were. That said, wallowing is much reduced, pretty much eliminated. There is no hit to road comfort as I'd braced myself for. It also looks great, I was a little worried about the lift amount with 32” tires under, but its handsome. After all 33" tires are only 1/2 inch taller in any direction from the hub. 33s also require mods to crash bars, possibly cutting, they're certainly heavier which reduced MPGs and, critically, range when you're out in the western hinterlands. So, I like my 32s and haven't found a reason to need them taller, yet.
Forgot to measure before heights.. damn. But after:
39” from ground to bottom of front wheel well trim, 40” in back wheel well. So, 1” of rake after 3” front and 1” back lift.
Drives straight and true after alignment. The numbers seem good and the shop was happy with them. They reported no trouble aligning with stock UCAs. Interested in feedback though, I’m not an expert
Alignment.
Before (before canopy, too). Same Firestone XTs before and after lift
After.
Icon Leaf
JoeDop1
Mojave Desert
2020 Ranger Lariat FX4 Crew Cab
Retired engineer
looks great and that is a very nice color!
Bob902
St. Louis
RETIRED!!!!
Looks good! I'm pleased with my Eibach setup as well.
RangerPNW
Thomas
Santa Fe, NM
Looking good!
lazynorse
lazynorse
Washington State
Public Health
Pre-lift photo here, this is the intended use. We were out for 10 days on this trip, different spot every night. My only other truck mods, if you can call them that, are Rhino Racks and Rooftop Box, then camp gear, fridge, jackery battery. Compressor, basic recovery gear. Haven’t felt the need or urge for bumpers and winches. Don’t want to budget for those either. Pretty well set for our use case. Used to abuse a Subaru Outback in similar ways, the Ranger is soooo much more capable and doesn’t break a sweat (or components) off the beaten path.
Egg69
Erik
Fallbrook, CA
2019 Ranger XLT Sport
Systems Analyst for Bonsall Unified School District
Alignment.
After.
Icon Leaf
Looks great!
Deleted User 61245811
Love mine too. I used the 1" block in the back and have the 33's. Looks, rides, handles, off-roads, so much better.
I just had one of my front Eibach shocks blow out. Contacted Eibach and they sent me a new one under the Million mile warranty. Pain to change but awesome service.
TJMarchand
Trevor
Medford, MA
2019 Ranger XLT / 1984 Monte Carlo SS
Looks awesome. My Eibach stuff is arriving today. Do you know if each of the fronts were set exactly the same or are they slightly different to make it even?
Tincan
Long Beach, California
2021 STX FX4
Dang that's a bummer on the blowout. Did you abuse it or how did it fail?
No abuse that I am aware of. Just crawled under to change my (engine) oil and saw the (shock) oil dump out of the shock. Didn't even know that it had happened. I do take the truck off road. Nothing extreme, but nothing a 2wd could do. I also tow heavy with it which is probably the most stressful thing for the truck itself.
lazynorse
lazynorse
Washington State
Public Health
The shop didn’t say so, and both fronts measure the same, ground to wheel well. I have the stage 1, adjusts with clips and those adjustments are not incremental so I doubt there’s a difference to accommodate weight of driver.
RealRigsRattle
Tim
Mesa, AZ
Looks awesome! I’m a former Outback abuser as well?
How are the Icon leafs holding up for you? I recently picked up a Eibach 2R setup. Only installed the rear shocks so far. They made a huge improvement but I only have about an inch of rake and obviously the factory leafs are terrible, so I’m looking for opinions.
Pics for attention
Here’s the Outback used to abuse?
Superdave62
Apache Junction, Az
2020 Ranger STX 4X4
HVAC Manager
I did the Eiback pro set with the front at 3” with OME 1.5” rear leafs. Also have icon UCA’s. Not sure I needed them but why not. It rides a little rough at very slow speeds but smooths out nicely when you pick up the pace a little. When I load up for camping there’s about 400lbs added and it rides pretty good at that point. Plus if I decide to go heavier with the gear the OME’s will handle the load. I’m happy with my set up.
