EGR DPFE Sensor Assembly Replacement Write-Up (LB5Z-9J433-B)
Trash Panda
Cody
Greetings All,
Dropping another one of my write-ups on the infamous bucking/surging epidemic our Rangers seem to have.
Check out the "Bucking/Surging Epidemic" thread started by @Tim Vogt Sr. for every piece of information you could want.
https://www.ranger5g.com/forum/threads/bucking-surging-epidemic.14581/
There are two ways to do this job, simply the replacing the DPFE Sensor itself (Ford KA1Z-5L200-A or KA1A-5L200-AB) or the entire assembly (Ford LB5Z-9J433-B). This write-up is geared towards replacing the entire assembly.
My symptoms were prevalent in the low RPM and low speed range. I drive like a peepaw and slowly pulling out of my driveway I would get a "misfire" feeling but no check engine light. I did my plugs last week so an actual misfire would be highly unlikely so my next step was the DPFE sensor. The transmission would search for gears at low RPMs and sometimes it would feel like driving a manual in too high of a gear through my neighborhood.
Supplies Needed :
-DPFE Sensor Assembly (Ford LB5Z-9J433-B) ($97 on @LevittownFordParts.com)
-3/8" or 1/4" Ratchet
-8mm shallow and deep sockets
-1.5" extension (if desired)
-Torque Wrench set to 97 in.lbs
-Needle Nose Pliers
-Straight-Jaw Pliers (I used my Milwaukee 6" 48-22-6306 pliers)
-LIGHT (Headlamp, Milwaukee Rover, etc)
-Work Platform or Step Ladder
Step One :
Pop the hood and locate the DPFE sensor. It is located near the back side of the engine on the driver's side of your Ranger near the brake booster.
STEP TWO : (*You could swap this with Step Three if desired)
Use your Ratchet and 8mm socket to loosen the single mounting bolt on the top. A deep socket is perfect for this without the brake booster being in the way.
Once you loosen the 8mm bolt, you can easily unthread it all the way using your fingertips to reduce the chances of dropping a socket or the bolt in to the engine bay.
*NOTE there is a washer with the 8mm bolt so be sure to not drop it.
STEP THREE : (*You could swap this with Step Two if desired)
Remove the connector from the DPFE sensor. If you read my Spark Plug write up, the connector works just like the coil pack connectors. Use your fingernail to slide the locking tab out (circled) and wiggle the connector off.
You can hang the connector out of the way on the metal line in the top right of the photo below to prevent damage.
STEP FOUR :
With the DPFE sensor unbolted and unplugged you can pull it out of the way to give you room to access the spring clamps on the hoses. This is where having a light is necessary. Take note of how the spring clamps are oriented. Mine were both facing relatively face-up. Removing the clamps is the most difficult part of the job so just stay calm and take it slow. I started with the shorter hose first to give me more leverage on the longer hose.
STEP FIVE :
Start with the smaller hose (closest to you) and go straight down with a pair of needle nose pliers (longer ones seemed to work better). When I pinched the spring clamp and pulled up the hose came right off. I did not have to fight it at all. Once the hose is off you can also place it to the side or out of the way to give you the most access to the long hose.
STEP SIX :
Remove the spring clamp on the longer hose (furthest from you). What worked for me was compressing the spring clamp, pliers in my right hand and pulling the hose horizontally to the right with my left hand. The DPFE sensor is now fully removed.
STEP SEVEN :
Reverse what you just did in Steps FIVE & SIX and take the new DPFE sensor and slide the long hose(Furthest from you) (yellow clip) on first and the short hose (closest to you) (white clip) on next.
Align the spring clamps facing upward as much as possible to make the job easier the next time you have to potentially perform it.
When the hoses are pushed on as far as possible twist the yellow and white clips clockwise to remove and engage the spring clamps.
STEP EIGHT :
Re-mount your new DPFE sensor using the guide pin and hand thread the 8mm bolt until snug to prevent cross threading. Take your torque wrench set to 97 in.lbs and torque the 8mm bolt. (It takes no effort at all and should click in a second or two)
STEP NINE :
Reconnect the DPFE connector. Slide the connector on until you hear a "click" and use your finger to engage the white locking tab by pushing it from the back towards you.
Crank your Ranger to see if a check engine light or any error message appears. Take a test drive around the neighborhood to see if there is an improvement in the surging/bucking in a low gear. I noticed an instant improvement on my Ranger and it drives like a brand new truck. Time will tell how long the replacement lasts.
That's it! Grab a cold one and enjoy a job well done! :sunglasses::beer:
Yet again it took me longer to write this write-up / take pictures than the actual job did. I would say it is a 30 - 45 minute job as long as you do not lose a socket or bolt in the engine bay. :crackup:
RedDakooter05
Illinois
2024 Nissan Frontier S 4x4
That rubber line is barely on that metal tube, wonder if that's where moisture is seeping in from.
Side note, you know the inside diameter for those hoses? I rather not pay that absurd $40+ mark up for short rubber hoses.
Trash Panda
Trash Panda
Cody
Looks like 0.25in for I.D. and 0.50in for O.D. per my Amazon calipers.
notsolinear
Illinois
2021 Ford Ranger Lariat
Maybe I’m misunderstanding your comment, but the rubber hoses engage quite far into those metal barbs, 3/4” or more if memory serves. The clamps are closer to the end of the tube, but it engages past those.
ChiefQM
Bill
Hiram, GA
2019 Ford Ranger XLT
When I gave up on Ford solving my bucking problem at low speeds, my salvation came when I saw a post about replacing the EGR DPFE valve. Part number KA1A-5L200-A was in stock at my local dealer (not the selling dealer) for $18 and change. I bought a foot of fuel injection-strength hose and four hose clamps. I changed it myself, pretty much following the procedure listed here, except that I used the old mounting bracket. Total cost about $28. This was 13 months ago and the truck has run perfect ever since.
Amsoil guy
Cloverdale, B.C.
Hydro Vac operator/ Amsoil Dealer
Greetings All,
Supplies Needed :
-Needle Nose Pliers
Step One :
STEP FOUR :
STEP FIVE :
STEP SIX :
STEP SEVEN :
STEP EIGHT :
STEP NINE :
Not trying to be a smart ass or anythIng, so please don’t take it that way. Isn’t a DPFE (Diesel Particulate Filter)? Is this the same thing you’re dealing with? Pic below.
Thanks,
J
Dahveed
Central Kansas
Pharmacy Consultant
Thanks,
J
DPFe is Differential Pressure Feedback. Which is the sensor that causes problems for us. Your code there looks like it could definitely be this issue.
Trash Panda
Trash Panda
Cody
Thanks,
J
Differential Pressure Feedback Sensor.
Based on that description you have it would appear to be this exact same sensor. Mine did not give me a code or anything yet ; has yours ever been changed?
Amsoil guy
Cloverdale, B.C.
Mine is still the original from new. I’ve had about 9 notifications on the same thing . Next day check engine light is off.
My buddy is a mechanic at one of the local Ford Dealerships near me and remotely ran a scan for the truck. The code came back as “ Hose is off or plugged. Wonder if it would be better off to just change it all out or just blow out the hose and hope that’s all it is.
Pic below of the diagnostic.
Trash Panda
Trash Panda
Cody
There are quite a few components of our truck’s EGR system so it could be any of the hoses or tubes in the below diagram. I do think there is enough data to say when we replace the DPFE assembly (like in my write-up) it fixes the weird issues.
I would go ahead and replace the entire assembly since you have not before and see if it improves the ride. If it still flashes a Check Engine Light then revisit knowing you have already replaced the DPFE assembly.
Trash Panda
Trash Panda
Cody
Just changed the thread title to reflect this is an EGR related issue to avoid confusion.
That is really good to hear you have had success. I think the biggest question everyone has is how long will the new part last, hopefully longer than the factory part. :crackup:
If yours does go out again at least you only have to loosen the 8mm bolt and your two hose clamps.
MrBusses
2019 Ranger 4dr FX4
Ford SMT
Change the DPFE and the egr tube. The tubes going to the dpfe can get clogged so it is likely that if you changed the sensor an still have problems the issue is in the tube. Also when you remove the sensor tap it a few times on the table and check for water coming out.
I did my sensor and tube at the same time and my sensor had water in it. Could I have gotten away without the tube? Maybe but I didn't want to work on it again.
ChiefQM
Bill
Hiram, GA
There were 12,400 miles (in six months of service) on the truck when I bought it - it was (allegedly) a Certified Pre-Owned vehicle - and so far, the replacement part has lasted 9K miles and 13 months. Of course, I drove it for 21K miles with the issue before I stumbled on the fix.
Shadowace
St johns
2019 ranger lariat
Driver
Shadowace
St johns
2019 ranger lariat
Driver
Just wondering if taking the sensor and tube's of and lightly blowing compressed air trough tube's and sensor would remedy the problem. I've been looking all over the place and seems there is nothing available.
