DIY: Adding the 12V Power Outlet Option in the Bed
mark_anderson_us
Chicago
Ford Ranger Lariat FX4 2020
Software Developer
As I posted in another thread. I have ordered (what I and a dealer parts guy) think is needed to add the outlet. Including hardware and the sub-harness. I will post pics of the install and part numbers to those interested. Waiting on parts from Detroit. Just a FYI drilling is required.
NOTE: 19N236B in the diagram below is not the correct part number. Should be 19N236A. See post #3 below for correct part numbers and quantities.
where did you order from?
Got the parts in. Looks to be complete. Will post install pics shortly.
Schulz says it does not fit vehicle: https://parts.schultzford.net/oem-parts/ford-socket-7a2z19n236a
WLFPIR8
Ethan
Central Ohio
whor.us
2019 Ranger Lariat FX4/Sport in Saber Orange
Systems engineer by day, maker and multimedia guru by night.
micl9
Apex, NC
2019 Ranger XLT Fx4 302A
Just finished installing one of Ethan's awesome Wolf Haus Aux Power Bed Harness. Went all out with both the Marine/Cigarette Lighter Socket and In Bed Connector (Pigtail), cause you never know...
My set up had an added twist as I wanted to tap off this harness to power bed lights. I asked Ethan if he could make a harness with a pigtail tap and he came thru!
Really impressed with the workmanship and just the innovation to come up with this design solution.
Does any know if we can use forescan to make this circuit active after an unlock? The bed light will be great when I arrive in the dark, but if I need to load in the dark it would be nice not to have to put the key in the ignition to enable the bed lights.
DanaBovender
Dana
From the Florida Panhandle Residing in Germany
2019 Ranger Lariat Supercrew 4x4
Gov Employee
micl9
Apex, NC
I have seen where others added a magnetic contact switch to the lights, if you open the tailgate they power on.
Yeah I considered doing that, but decided to keep it simple and minimize wires.
I also chopped the switch that came with my Nilights in place of one I could mount thru the hole in the back of the bed.
Finished job! Thanks again Ethan!
Racket
Here and There
2019 Lariat Supercrew 2WD
Transient
The naked bed for those of us with liners: (considering the Wolfhause kit)
WLFPIR8
Ethan
Central Ohio
whor.us
Kits are all 10% off right now (until the end of November) with the code RANGER10 FYI
micl9
Apex, NC
Order the Wolfhause kit. You won't regret it. Simple install and works great!
Absolutely!
Very well made.
IMHO better than the stock bed power plug. No holes to cut. Better in bed power socket (lighter vs 2 prong). Option to have a pigtail tap to power something else (bed lights in my case).
Racket
Here and There
Transient
Broke down and ordered. Everyone loves a
Black Friday Sale!
Hi Folks,
I paid full price...I still consider this a bargain! Worth every penny! Well done high quality!
Phi Schilke
mark_anderson_us
Chicago
Software Developer
Seems to be a long way forward in bed: maybe just focal length of lens?. how far is it from tailgate
mark_anderson_us
Chicago
Software Developer
I wanna pick one of these up, but can't decide on connection. Sounds like it's a straight 12v cigarette lighter socket or plug with this on a pigtail. What's the benefit of the latter?
micl9
Apex, NC
It's not that far fwd, behind the wheel. See Rackets post after mine. It goes in the rectangular hole above the 2 oval holes/plugs.
I got both. One is lighter socket and the other is just 2 tinned wires ready to hardwire whatever.
I figured having it on hand when I need it/find a use was worth it.
