DIY: Adding the 12V Power Outlet Option in the Bed
Akshon
San Diego, California
19 Ranger Lariat FX4 Crew Magnetic
As I posted in another thread. I have ordered (what I and a dealer parts guy) think is needed to add the outlet. Including hardware and the sub-harness. I will post pics of the install and part numbers to those interested. Waiting on parts from Detroit. Just a FYI drilling is required.
NOTE: 19N236B in the diagram below is not the correct part number. Should be 19N236A. See post #3 below for correct part numbers and quantities.
Advertisement
dguffin
Dana
Aberdeen, SD
20 Corsair, 19 Ranger, 12 Boss, 08 Zuma
Shop Foreman
I would definitely be interested in that information.
Thanks
Akshon
Akshon
Ok for the install you will need a 2-1/8” hole saw, 5/16” drill bit, flat and round file, Rust preventative paint of your choice.
Drill a 2-1/8” hole in the side bed wall near the left rear cleat. (See photos below) Use caution when drilling or you will end up with dings protruding from your outer fender. You can position a block of wood or stuff a bunch of rags up into the cavity from below to orevent damage.
Insert the power port body into the opening and mark the location of the 4 screw holes. Drill 4- 5/16” holes. Debur all holes using a round file.
Using a flat file, in the large opening, create 4 flat areas adjacent to the 5/16” holes. Insert the 4 captive nuts into the body with the threads inboard the fender. Paint all exposed metal with rust preventative paint.
Install the sub-harness onto the socket and feed the wire down the inner fender well. Install 4 retaining screws.
Under the truck, remove the dummy plug from the body harness and insert the power port sub-harness. There is one large hole on the sheet metal pillar opposite the tail light cavity for the “christmas tree style” zip tie retainer that is included on the sub-harness.
I ended up adding a few extra zip ties to secure the wiring.
Thats about it. Time-about 30 minutes.
Pics below...
magnet79
Randy
Toledo, OH
2019 Ford Ranger SuperCrew XL STX FX4; 2003 Nissan Altima 3.5 SE
Bartender
What was the total cost on this? And, showing my ignorance here but, that gets you a typical household-style outlet there?
rangerdanger
SF Bay Area
I think parts are about $75.
Akshon
Akshon
Parts were about $65. The alternative being to find/order a truck with the “Bed Utility Package” 86Q which comes with a plastic drop in bedliner.
This gets you a 20 amp- 12 Volt outlet. Similar to those in the dash. You could probably run a small 12-120v inverter off of it.
Rinn69
N. Central Iowa
Retired USAF MSgt
Don't forget to slap some dielectric grease on the contact points :thumbsup:
ulev1st
Don
West Tn
2019 Ranger CC FX4 ,2012 F250 Lariat FX4, 2017 Shelby GT350, 14 Ford Focus
Retire Marine and Refinery Operator
Internally like a lighter outlet?
THLONE
Thom
Tucson,AZ
68 Chev C-20, 1996 Ford 1t Powerstroke 4X4, 2019 Ford Ranger XL 4X4
No smoking in the bed. LOL
Is it hot all of the time or only when the ign is on?
Akshon
Akshon
Hot @ all times. But controlled via the BCM so if battery voltage drops below threshold it will shut it down.
There is most likely a PID for it in the BCM. On my 17 Escape I was able to change the power port state using Forscan (Hot at all times or Hot with ign on). Have yet to poke around the trucks modules.
RJohans
Robert
Bend, Oregon, USA
2019 Ford Ranger Lariat 4x4 Supercrew Sport
Project Manager
Nice job! IMHO, having a 12V CLA in the truck bed seems much more practical than the two currently in the dash.
Advertisement
Advertisement
