Diff Drop - Anybody here do one?
Glocker
Glocker
Boca Raton
Okay so that diff drop is not for the faint of heart. Took several hours and you better have a right angle drill and good bits. I will post pictures tomorrow.
Did you have to remove anything like control arms or other suspension parts?
Dr3wDrop
Andrew
OHIO
2021 Lariat Tremor
nope. Just just crawled under the truck, supported the diff with a Jack and started cutting away with a sawzaw. Man do I hate that tool. I would much rather use a cut off wheel any day of the week but there was not much room to work with.
Glocker
Glocker
Boca Raton
I'm lucky - I'll be doing mine on a lift next weekend. Fingers crossed for a good result!
RCMUSTANG
Ray
Los Angeles
2017 Fusion 1995 Ranger
Did the drill type kit in a couple hours and noticed no difference from before. Not that there was an issue before.
Dr3wDrop
Andrew
OHIO
2021 Lariat Tremor
If you figure out what this ring is for lmk. It was not covered in the instructions
Glocker
Glocker
Boca Raton
@Glocker How did the install go?
It went longer than I expected. The passenger side went really easy. The template for the driver side didn't match up at all! So we did a part of the driver side (driver side inner bracket first), and then used the driver side outer bracket to determine where to drill the holes. Everything looks good and I haven't had any weird issues/noises/etc. out of the truck. I didn't determine what the aluminum ring is for either. LOL
I have to say, it was great doing it on a lift with a transmission jack/support. I think it saved our back!
Doc
Doc
Live oak fla
2026 5.0 Mustang GT, 2024 Ranger STX, 2015 Cadillac SRX
Good Job !
Dr3wDrop
Andrew
OHIO
2021 Lariat Tremor
I did the same thing. Cut about where I thought I needed too, bolted up the inside bracket and slid the bolt through backwards towards the driver side to go into the new bracket. Once I got the bottom hole drilled I slid a bolt in and drilled a pilot hole for the top hole and then removed the bracket to finish.
seanellaz
Sean
Tucson, AZ
Healthcare
Learn something new everyday. All this time I thought all the posts referred to the rear differential. Actually just looked on BDS website and searched for a differential drop kit and the only thing that populated was for a Dodge truck. I am with Phil, I won't be cutting on anything including the frame, if I do this I want plug and play.
I have the 3.5" BDS kit on my Ranger. The diff drop is of heavier steel than the factory one. Plus location of factory drop would seem to block any mod. I cannot see how any diff drop would avoid cutting off the factory welded one. The BDS Drop comes w/ their lift n level kit. VERY happy with it. SUPER Stout. PITA to install.
BladeRanger
Bladimir
Escondido Ca
Ranger 2020 XLT FX4
Electronic Engineer
Looks good.
the idea of cutting the frame on a new truck is not something im gonna do. i want to put on the bilstein 5100 shocks and struts and get a little bit of lift / level but if its going to make problems i may just skip the headache. any one have a "safe range" suggestion? the ride height is adjustable, i do not NEED lift for bigger tires etc. i mainly want the upgraded shocks and struts. i would like to have the front closer to level but still have the truck raked a bit.
Glocker
Glocker
Boca Raton
How much do you use your truck off road? Funny thing; being lifted in the 3.5" to 3.75" range, I had no problems off road. But three times, while turning left out of driveways on asphalt surfaces, I heard a little binding up front on the right side. That's what drove my desire to drop the diff., just in case. I've been out a bunch without any issues though.
I also retained the parts cut off, and they can be easily welded back in just a couple of minutes. :D
I think you will probably be fine with your desired level of lift with the 5100 shocks and struts.
